[SOLVED] Saved Process fails if it has an Octave Script Operator
Hello,
I recently upgraded to Rapidminer 6.3 and I experienced a problem with the Octave Script Operator. I noticed that if I save a process containing such operator the process fails to execute again as long as the operator is present. If I remove the operator the process runs again. The process did not fail until I saved it. I tried also to run processes created with Rapidminer 5.3, which I also have installed, with the same result. However processes created with both versions run without any problem in Rapidminer 5.3.
I have octminer version 2.2.003.
I submitted the report to the bug-tracker here:
http://bugs.rapid-i.com/show_bug.cgi?id=1854
I hope you can help me. I thank you in advance for your time.
Best regards,
Germán.
Best regards,
Germán.
