🎉Community Raffle - Win $25
Join and Win
"Using macro to set database parameter"
User: "EMDuell"
New Altair Community Member
Updated by Jocelyn
Hello,
I would like to use a macro to set parameters in my database connection that is published on a RapidAnalytics server - for example, I would like to be able to have the string published, but modify a parameter like oauthaccess token at runtime.
I attempted to use %{oauthaccesstoken} in the database connection setup on the server, and then to set that macro in RapidMiner locally when it run, but it throws an error.
Does anyone know if this is possible?
Thanks,
Eric
