"[SOLVED] Problem after installing RapidMiner Server"
Hi All,
I have installed RM server 2.3 on my Windows server called Fuji. Then I run the RapidMiner_Server service.
Everything is fine, the log (see below) doesn't show any error but
when I try to access to http://fuji:8080 (or http://localhost:8080), the web page is not available and I'm redirected to http://localhost:8080/RA/faces/restricted/index.xhtml
Massimiliano
Any ideas ?
11:12:20,544 INFO [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
11:12:21,730 INFO [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
11:12:21,917 INFO [org.jboss.as] (MSC service thread 1-3) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
11:12:21,964 DEBUG [org.jboss.as.config] (MSC service thread 1-3) Configured system properties:
awt.toolkit = sun.awt.windows.WToolkit
file.encoding = Cp1252
file.encoding.pkg = sun.io
file.separator = \
java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment
java.awt.printerjob = sun.awt.windows.WPrinterJob
java.class.path = F:\\Programmi\\RapidMiner\\\jboss-modules.jar
java.class.version = 52.0
java.endorsed.dirs = C:\Program Files (x86)\Java\jre1.8.0_31\lib\endorsed
java.ext.dirs = C:\Program Files (x86)\Java\jre1.8.0_31\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home = C:\Program Files (x86)\Java\jre1.8.0_31
java.io.tmpdir = C:\Windows\TEMP\
java.library.path = C:\Program Files (x86)\Java\jre1.8.0_31\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;;.
java.net.preferIPv4Stack = true
java.runtime.name = Java(TM) SE Runtime Environment
java.runtime.version = 1.8.0_31-b13
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_31
java.vm.info = mixed mode
java.vm.name = Java HotSpot(TM) Client VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.31-b07
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = F:\Programmi\RapidMiner
jboss.host.name = fuji
jboss.modules.dir = F:\Programmi\RapidMiner\modules
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = fuji
jboss.qualified.host.name = fuji
jboss.server.base.dir = F:\Programmi\RapidMiner\standalone
jboss.server.config.dir = F:\Programmi\RapidMiner\standalone\configuration
jboss.server.data.dir = F:\Programmi\RapidMiner\standalone\data
jboss.server.default.config = standalone.xml
jboss.server.deploy.dir = F:\Programmi\RapidMiner\standalone\data\content
jboss.server.log.dir = F:\Programmi\RapidMiner\standalone\log
jboss.server.name = fuji
jboss.server.persist.config = true
jboss.server.temp.dir = F:\Programmi\RapidMiner\standalone\tmp
line.separator =
logging.configuration = file:F:\\Programmi\\RapidMiner\\\standalone/configuration/logging.properties
module.path = F:\\Programmi\\RapidMiner\\\modules
org.jboss.boot.log.file = F:\\Programmi\\RapidMiner\\\standalone\log\server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = x86
os.name = Windows Server 2008 R2
os.version = 6.1
path.separator = ;
program.name = standalone.bat
sun.arch.data.model = 32
sun.boot.class.path = C:\Program Files (x86)\Java\jre1.8.0_31\lib\resources.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\rt.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\sunrsasign.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\jsse.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\jce.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\charsets.jar;C:\Program Files (x86)\Java\jre1.8.0_31\lib\jfr.jar;C:\Program Files (x86)\Java\jre1.8.0_31\classes;F:\\Programmi\\RapidMiner\\\jboss-modules.jar
sun.boot.library.path = C:\Program Files (x86)\Java\jre1.8.0_31\bin
sun.cpu.endian = little
sun.cpu.isalist = pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop = windows
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = F:\\Programmi\\RapidMiner\\\jboss-modules.jar -mp F:\\Programmi\\RapidMiner\\\modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=F:\\Programmi\\RapidMiner\
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = Cp1252
sun.management.compiler = HotSpot Client Compiler
sun.os.patch.level = Service Pack 1
sun.rmi.dgc.client.gcInterval = 3600000
sun.rmi.dgc.server.gcInterval = 3600000
user.country = IT
user.dir = F:\Programmi\RapidMiner\bin
user.home = C:\Windows\system32\config\systemprofile
user.language = it
user.name = FUJI$
user.script =
user.timezone = Europe/Berlin
user.variant =
11:12:21,964 DEBUG [org.jboss.as.config] (MSC service thread 1-3) VM Arguments: -Dprogram.name=standalone.bat -Xrs -Xms512M -Xmx1024M -XX:MaxPermSize=256M -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Djboss.modules.system.pkgs=org.jboss.byteman -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=F:\\Programmi\\RapidMiner\\\standalone\log\server.log -Dlogging.configuration=file:F:\\Programmi\\RapidMiner\\\standalone/configuration/logging.properties -Xbootclasspath/a:F:\\Programmi\\RapidMiner\\\jboss-modules.jar
Massimiliano
1 - 4 of
41
this is only the start of the log. Please add the whole server.log, for example here: http://pastebin.com
Otherwise it's impossible to tell what went wrong.
Regards,
Marco
