problem with RM Server,
acuriel
acuriel New Altair Community Member
edited November 2024 in Community Q&A
Hi!!
My RM server 1.03.015 and  RM server 2.2.0 have an error, these are installed on the same computer:
Deployment "jboss.web.deployment:war=/RA" is in error due to the following reason(s): org.jboss.deployers.spi.DeploymentException: URL file:/appserver/rapidCE/server/default/tmp/vfs/automount5e792a728d6f0995/RapidAnalytics_War.war-98824716d4a12c3/ deployment failed
I need to help
thanks
Answers
  • Marco_Boeck
    Marco_Boeck New Altair Community Member
    Hi,
    1. You can only run one server at the same time on one machine unless you change all ports of the second server to different ones. Otherwise, they will interfere with each other, causing problems.
    2. The error message you posted says nothing. If you're having trouble with RapidMiner Server 2.x, please shut down the server, remove the Server/standalone/log/server.log file, try starting the server again and then post the whole content of the newly created server.log here.
    Regards,
    Marco
  • rapidprototypec
    rapidprototypec New Altair Community Member
    I had similar problem before.
Welcome!
Welcome!
