🎉Community Raffle - Win $25
Join and Win
[SOLVED] Results Window does not work
gfronvUser: "gfronv"
New Altair Community Member
Updated by Jocelyn
After some trials with RapidMiner Studio Starter 6.1.000 I have to realize today that it does not work anymore. ???
Even if I try the tutorial "The First Process" :
After pushing the Run Button
I can see "creating display" at the right corner for half a second and the 'Results Button' is activated instead of the 'Design Button'
but the Design Window does not switch to the Results Window
The only thing that changes is that the green circles at the operators turn to yellow
and I can not click to anything except the items in the menu line.
The problems view tells me "no problems found" and no Error message or anything else pops up.
When I activate the 'Design Button' again, the operator are green again
and I can drag and drop and all that things but it is not possible to run a process
Even if I close RapidMiner and start again it is the same Problem
So the question is what can I do now?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.1.000">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Deals" width="90" x="179" y="210">
       <parameter key="repository_entry" value="//Samples/data/Deals"/>
     </operator>
     <operator activated="true" class="decision_tree" compatibility="6.1.000" expanded="true" height="76" name="Decision Tree" width="90" x="380" y="210"/>
     <connect from_op="Retrieve Deals" from_port="output" to_op="Decision Tree" to_port="training set"/>
     <connect from_op="Decision Tree" from_port="model" to_port="result 1"/>
   </process>
 </operator>
</process>
[/ code]
1 - 10 of 101
    Hi,
    what OS are you using? Which Java version (if you are not using Windows)?
    Can you please post the contents of the USER_HOME/.RapidMiner/rapidminer-studio.log file after this occurs?
    Regards,
    Marco
    OP
    Hello Marco
    I am using Windows 7 Enterprise Service Pack 1
    The rapidminer-studio.log looks like that:
    ov 14, 2014 3:42:33 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Nov 14, 2014 3:42:33 PM com.rapidminer.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Nov 14, 2014 3:42:33 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Cloud Connectivity
    INFO: Register plugin: Cloud Execution
    INFO: Register plugin: Data Editor
    INFO: Register plugin: Operator Recommender
    INFO: Register plugin: Process Scheduling
    INFO: Register plugin: Social Media
    Nov 14, 2014 3:42:34 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: recommenders
    INFO: Register plugin: Intelligent Discovery Assistant
    INFO: Register plugin: ProM
    INFO: Register plugin: MLWizard
    INFO: Register plugin: Anomaly Detection
    INFO: Register plugin: Reporting
    INFO: Register plugin: Series
    Nov 14, 2014 3:42:35 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Salesforce Connection.
    INFO: Registered configurator Amazon S3 Connection.
    INFO: Registered configurator Dropbox Connection.
    INFO: Registered configurator Twitter Connection.
    Nov 14, 2014 3:42:36 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    INFO: Default version of expression parser registered successfully
    Nov 14, 2014 3:42:39 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    Nov 14, 2014 3:42:39 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    Nov 14, 2014 3:42:39 PM com.rapidminer.tools.config.ConfigurationManager loadConfiguration
    INFO: Load configuration for Amazon S3 Connection.
    Nov 14, 2014 3:42:39 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
    INFO: No configuration file found for Amazon S3 Connection
    INFO: Loaded configurations for 0 objects of type Amazon S3 Connection.
    INFO: Load configuration for Dropbox Connection.
    INFO: No configuration file found for Dropbox Connection
    INFO: Loaded configurations for 0 objects of type Dropbox Connection.
    INFO: Load configuration for Salesforce Connection.
    INFO: No configuration file found for Salesforce Connection
    INFO: Loaded configurations for 0 objects of type Salesforce Connection.
    INFO: Load configuration for Twitter Connection.
    INFO: No configuration file found for Twitter Connection
    INFO: Loaded configurations for 0 objects of type Twitter Connection.
    Nov 14, 2014 3:42:44 PM com.rapidminer.elico.ida.IDAPluginInit initGui
    INFO: Initializing IDA GUI
    Nov 14, 2014 3:42:44 PM com.rapidminer.elico.ida.gui.dockable.WelcomeStep whitify
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@3047357a,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/RapidMiner/RapidMiner%20Studio/lib/rapidminer-studio-core-6.1.0.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import Excel Sheet...,defaultCapable=true]
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@3047357a,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/RapidMiner/RapidMiner%20Studio/lib/rapidminer-studio-core-6.1.0.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import CSV File...,defaultCapable=true]
    INFO: Whitify com.rapidminer.gui.tools.ExtendedHTMLJEditorPane[,0,0,0x0,invalid,layout=javax.swing.plaf.basic.BasicTextUI$UpdateHandler,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.basic.BasicBorders$MarginBorder@6f7cafd1,flags=296,maximumSize=,minimumSize=,preferredSize=,caretColor=javax.swing.plaf.ColorUIResource[r=0,g=25,b=100],disabledTextColor=javax.swing.plaf.ColorUIResource[r=180,g=180,b=180],editable=false,margin=javax.swing.plaf.InsetsUIResource[top=4,left=6,bottom=4,right=6],selectedTextColor=javax.swing.plaf.ColorUIResource[r=255,g=255,b=255],selectionColor=javax.swing.plaf.ColorUIResource[r=150,g=150,b=170],kit=com.rapidminer.gui.tools.ExtendedHTMLEditorKit@1307f559,typeHandlers=]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=8388608,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    ..will be continued in the next post
    OP
    .log continued:
    INFO: Whitify javax.swing.Box[,0,0,0x0,invalid,layout=javax.swing.BoxLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@2145d31c,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=8,height=32767],minimumSize=java.awt.Dimension[width=8,height=0],preferredSize=java.awt.Dimension[width=8,height=0]]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@6f26e454,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=32767,height=0],minimumSize=java.awt.Dimension[width=0,height=0],preferredSize=java.awt.Dimension[width=0,height=0]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@7c3444c,flags=328,maximumSize=java.awt.Dimension[width=200,height=200],minimumSize=java.awt.Dimension[width=200,height=200],preferredSize=java.awt.Dimension[width=200,height=200],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165832,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=5,height=32767],minimumSize=java.awt.Dimension[width=5,height=0],preferredSize=java.awt.Dimension[width=5,height=0]]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.EmptyBorder@24b8dd8f,flags=9,maximumSize=java.awt.Dimension[width=620,height=1000],minimumSize=java.awt.Dimension[width=620,height=80],preferredSize=java.awt.Dimension[width=620,height=210]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@7c3444c,flags=328,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165832,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,hidden,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/RapidMiner/RapidMiner%20Studio/lib/rapidminer-studio-core-6.1.0.jar!/com/rapidminer/resources/icons/16/error.png,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@7c3444c,flags=328,maximumSize=java.awt.Dimension[width=350,height=250],minimumSize=java.awt.Dimension[width=350,height=100],preferredSize=java.awt.Dimension[width=350,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165832,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=10,height=32767],minimumSize=java.awt.Dimension[width=10,height=0],preferredSize=java.awt.Dimension[width=10,height=0]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@7c3444c,flags=328,maximumSize=java.awt.Dimension[width=500,height=250],minimumSize=java.awt.Dimension[width=500,height=100],preferredSize=java.awt.Dimension[width=500,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165832,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    Nov 14, 2014 3:42:44 PM com.rapidminer.elico.ida.installer.InstallerUtils readCurrentVersion
    INFO: Current IDA version is 01.023
    Nov 14, 2014 3:42:44 PM com.rapidminer.elico.ida.installer.IDAUpdater checkForUpdateNow
    INFO: IDA is up to date.
    Nov 14, 2014 3:43:17 PM com.rapid_i.deployment.update.client.UpdateManager$4 run
    INFO: Checking for recently purchased extensions.
    INFO: No recently purchased extensions found.
    Nov 14, 2014 3:43:59 PM com.rapidminer.tools.WrapperLoggingHandler log
    INFO: No filename given for result file, using stdout for logging results!
    Nov 14, 2014 3:43:59 PM com.rapidminer.Process loadInitialData
    INFO: Loading initial data.
    Nov 14, 2014 3:43:59 PM com.rapidminer.Process run
    INFO: Process starts
    Nov 14, 2014 3:43:59 PM com.rapidminer.Process saveResults
    INFO: Saving results.
    INFO: Process finished successfully after 0 s
    Nov 14, 2014 3:47:00 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
    INFO: Running shutdown sequence.
    OP
    I did not tell you my java version until now:
    This is 7.0.450.18
    Hi,
    this sounds very weird. Your process is very simple and works just fine here. I noticed you use quite a few 3rd party extensions where we don't their inner workings. Because I have never heard of your problem and the log does not contain any clue whatsoever, can you try turning extensions off?
    To do so, please go to the preferences via "Tools" -> "Preferences" in the top menu bar and navigate to "Start-up". Uncheck "Initialize extensions" and then restart Studio and see if that helps. If it works now, an extension is the culprit.
    I would then suggest removing all your installed 3rd-party extensions (see below), enable the setting again and re-add the 3rd-party extensions one by one. If you check again after each new extension, you should find out the one which is causing all this.
    Your 3rd-party extensions:
    -  recommenders
    - Intelligent Discovery Assistant
    - ProM
    - MLWizard
    - Anomaly Detection
    Regards,
    Marco
    OP
    Hi Marco
    Thank you for your suggestions. :(
    Now I turned off my extensions but with the same result:
    I tried one of your sample processes "01_DecisionTree"
    Again after pushing the play Button I can see that the Results Window Button is activated but the screen does not change to that window
    Here the actual log file:
    Nov 17, 2014 10:33:41 AM com.rapidminer.tools.I18N <clinit>
    Nov 17, 2014 10:33:41 AM com.rapidminer.license.ProductConstraintManager initialize
    Nov 17, 2014 10:33:41 AM com.rapidminer.tools.plugin.Plugin initAll
    INFO: Plugins skipped.
    Nov 17, 2014 10:33:41 AM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    Nov 17, 2014 10:33:43 AM com.rapidminer.tools.jdbc.JDBCProperties <init>
    Nov 17, 2014 10:33:43 AM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    Nov 17, 2014 10:33:51 AM com.rapid_i.deployment.update.client.UpdateManager$4 run
    Nov 17, 2014 10:33:52 AM com.rapid_i.deployment.update.client.UpdateManager$4 run
    Nov 17, 2014 10:34:14 AM com.rapidminer.tools.WrapperLoggingHandler log
    Nov 17, 2014 10:34:14 AM com.rapidminer.Process loadInitialData
    Nov 17, 2014 10:34:14 AM com.rapidminer.Process run
    INFO: Process //Samples/processes/01_Learner/01_DecisionTree starts
    INFO: Process //Samples/processes/01_Learner/01_DecisionTree finished successfully after 0 s
    Nov 17, 2014 10:34:14 AM com.rapidminer.Process saveResults
    Nov 17, 2014 10:40:45 AM com.rapidminer.tools.WrapperLoggingHandler log
    Nov 17, 2014 10:40:45 AM com.rapidminer.Process loadInitialData
    Nov 17, 2014 10:40:45 AM com.rapidminer.Process run
    Nov 17, 2014 10:40:45 AM com.rapidminer.Process saveResults
    Hi,
    ok, then I assume some GUI settings are for some reason broken beyond repair.
    Can you try navigating to C:\users\XYZ\.RapidMiner and backup and then delete both the 'vlperspective-predefined-design.xml' and 'vlperspective-predefined-result.xml' files?
    If that does not work either, you can also try to backup and then delete 'rapidminer-studio-settings.cfg'.
    That way, all your custom settings for GUI elements should be gone and resetted to the default ones.
    Regards,
    Marco
    OP
    Thank's a lot Marco!
    After deleting 'vlperspective-predefined-design.xml' and 'vlperspective-predefined-result.xml' files the results window works again.
    One last question:
    Is it the normal condition for the "Starter Version" that I have to install the license each time i am starting RapidMiner?
    Kind Regards
    Ron
    Hi,
    no. If you install Starter once, it will not ask you to install it again. It will however show a prompt that you are using starter each time.
    If you are forced to enter the license each time, I would suspect a problem with the .RapidMiner folder in general. Is there something special about your user?
    You can try to backup the licenses folder and the license.properties, then delete both. The next time you start Studio you should be prompted for a license. When you then enter your Starter license, it should not ask you again the next time you start it.
    If it does, then it seems like there is some problem writing to your .RapidMiner folder, which could be caused by permission issues or some hardware failure..
    Regards,
    Marco
    OP
    Thank you Marco - looks good now
