Import Data Problem
Hello, I got one problem here, when I import data from excel file, the value for "May 1" been changed to "April 30", and "July1" become "June 30". This problem occured when I import data into RapidMiner Server repository folder, but, when I try import the same data into Local Repository, the data remains as original one.
Somebody please help me, I am an intern student and very new to RapidMiner.
1 - 1 of
11
the problem you describe are very likely caused by different timezone configurations for your local RapidMiner Studio and the remote server. By default the system time settings are used. You may either set both timezone settings to the same value or use an operator like "Adjust Date" to bridge the gap.
Cheers,
Helge
