🎉Community Raffle - Win $25
Join and Win
Modifying a nominal value if another variable satisfies condition from huge set
User: "zolifu"
New Altair Community Member
Updated by Jocelyn
This is done in sql with select ,,where ..and hundreds of OR operators.
Here with Filter only a short list could be entered, Replace dictionary doesn't seem to work for this...any suggestion how to use a huge list of values to check in OR condition?
Thanks
1 - 1 of 11
    User: "homburg"
    Hi zolifu,
    you may take a closer look at "Generate Attributes". This operator allows you to build a statement dealing with existing attributes to create something like an indicator variable for further processing.
    Cheers,
    Helge
