Problems with export
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey,
i i try to export my model - independently from the kind of the model (RADIOSS,stl etc.) - i got an error code (attached picture) and i have no idea why. I hope somebody can help me.
Best Max
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Which version of Hyperworks you are using? User profile & Export format?
    Altair Employee
    OP
    Hey,
    I'm using version 14.0 and i tried to export my model in a radioss format (Block 140) and what do you mean by user profile?
    Best,
    Max
    Altair Employee
    OP
    Hi Max,
    Is it possible to share the HyperMesh file?. Please share through the secure drop box link which is available in my signature.
    Altair Employee
    OP
    Done!
    Thank you very much for your help.
    Best,
    Max
    Altair Employee
    OP
    Hi Max,
    Select the user profile based on the solver you are using and build the model on the same user profile, which is the solver interface. That is, when you are using RADIOSS as a solver, select RADIOSS from the user profile. Create the FE model (material, property, loads, boundary conditions..etc) and then export it to RADIOSS format and solve in RADIOSS solver. Please try exporting the same model after loading the RADIOSS user profile.
    User profiles in HyperMesh automatically manage the loading of templates and FE-input readers for a given solver interface in the current HyperMesh session.
    Altair Employee
    OP
    Ok! It worked.
    Best
    Max
