Hey,
i i try to export my model - independently from the kind of the model (RADIOSS,stl etc.) - i got an error code (attached picture) and i have no idea why. I hope somebody can help me.
Best Max
Which version of Hyperworks you are using? User profile & Export format?
I'm using version 14.0 and i tried to export my model in a radioss format (Block 140) and what do you mean by user profile?
Best,
Max
Hi Max,
Is it possible to share the HyperMesh file?. Please share through the secure drop box link which is available in my signature.
Done!
Thank you very much for your help.
Select the user profile based on the solver you are using and build the model on the same user profile, which is the solver interface. That is, when you are using RADIOSS as a solver, select RADIOSS from the user profile. Create the FE model (material, property, loads, boundary conditions..etc) and then export it to RADIOSS format and solve in RADIOSS solver. Please try exporting the same model after loading the RADIOSS user profile.
User profiles in HyperMesh automatically manage the loading of templates and FE-input readers for a given solver interface in the current HyperMesh session.
Ok! It worked.
Best
