"Want to filter tokens by content using multiple words"
I want to filter reddit.com page data and I want to filter out 'reddit', 'url', and 'points' among other words. I only seem to be able to enter a single string into the filter tokens (by content) parameter, using the contains option.
I found this forum post that claimed I could use the regex OR operator '|' http://rapid-i.com/rapidforum/index.php/topic,3476.0.html
This is not working for me. What can I do? Thanks!
1 - 1 of
11
please follow the guidelines mentioned here: http://rapid-i.com/rapidforum/index.php/topic,4654.0.html
Especially post your process xml of your process so far (or a simple example that demonstrates the problem).
It's a bit hard to help when all the information you get is "xyz is not working for me"
Regards,
Marco
