"[SOLVED] RapidMiner Server Installation - Root Directory Does not Exist"
Hi Team!
While try to install RapidMiner Server in my system got the below mentioned error. Your suggestion to resolve this issue is appreciated.
Download Link Location: http://go.rapidminer.com/rm6-server-download-full
OS: Windows 7
Java version: "1.7.0_17"
Database: MySQL
Error Message:
com.rapidanalytics.installer.gui.ProgressDialog update SEVERE: An error occurred! Installation failed! java.io.IOException: Root directory does not exist
Below is the installer file got created:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd">
<properties>
<entry key="db_url">localhost</entry>
<entry key="db_port">3306</entry>
<entry key="server_service_id_overwrite">null</entry>
<entry key="eula_accepted">true</entry>
<entry key="server_port">8080</entry>
<entry key="db_password">root</entry>
<entry key="installation_directory">D:\</entry>
<entry key="mail_password"/>
<entry key="license_key"/>
<entry key="server_host">SYSTEM1</entry>
<entry key="server_register_as_service">true</entry>
<entry key="db_driverclass">com.mysql.jdbc.Driver</entry>
<entry key="mail_port">25</entry>
<entry key="server_service_linux_variant">SUSE</entry>
<entry key="mail_sender"/>
<entry key="memory_max">1024</entry>
<entry key="db_system">MySQL</entry>
<entry key="mail_url"/>
<entry key="java_home">C:\Program Files\Java</entry>
<entry key="server_service_name">RapidMiner_Server</entry>
<entry key="db_user">root</entry>
<entry key="server_service_id">RMS20007SVC</entry>
<entry key="server_host_bind_only">false</entry>
<entry key="mail_user"/>
<entry key="db_driver_path">C:\Users\[UserName]\Downloads\RapidMiner-Server-Installer-2.0.007\rapidminer-server-installer\data\jdbc\mysql-connector-java-5.1.24-bin.jar</entry>
<entry key="db_schema">Test</entry>
</properties>
OS: Windows 7
Database: MySQL
Error Message:
<properties>
</properties>
the reason is that you tried to install it directly to
Regards,
Marco
