"[SOLVED]questions of reading csv files"
When using “read csv” operator to import csv file, I have the following problem.
If a given cell has a “,”, the word following it will not be read. I think this is because the “,” is used as the column operator. But for this case, “,” is just an character appeared in a string . How can I let rapidminer skip this “,” in the string.
The following is the test csv file, which just include one row with two columns. The main content is just a text string. in the gnerated wordlist, we can find that the word "what" was not read due to the "," appearing before it.
The following is the process
ID Text Field 1 wow <Content>, what charm! |
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="5.3.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="165">
<parameter key="csv_file" value="C:\Users\LocalRepository\Source_Data\test3.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="GBK"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="ID.true.integer.id"/>
<parameter key="1" value="Text Field.true.text.attribute"/>
</list>
</operator>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="120">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (3)" width="90" x="179" y="120"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (3)" width="90" x="313" y="120"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (3)" width="90" x="447" y="120">
<parameter key="min_chars" value="1"/>
<parameter key="max_chars" value="200"/>
</operator>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="255"/>
<connect from_port="document" to_op="Tokenize (3)" to_port="document"/>
<connect from_op="Tokenize (3)" from_port="document" to_op="Transform Cases (3)" to_port="document"/>
<connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="word list" to_port="result 1"/>
</process>
</operator>
</process>
