Dynamic Loads Topology Optimisation in Optistruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
The problem consists of a connecting rod submitted to axial loads which define the phases of admission (traction) and combustion (compression).
I am trying to run the following optimization:
  • 2 load steps :
    • Traction
    • Compression
  • 2 responses :
    • Volume
    • Compliance
  • 1 constraint :
    • 60% Volume
  • 1 objective :
    • Minimize compliance
I managed to run a direct transient analysis for the two separate load cases.
I tried running a topology optimization for one of the load cases but an error occured with the following message:
*** ERROR # 557 ***  DRESP1 2 is not referenced from within a static or an MBD SUBCASE.
This type of response must be specified from within a static or an MBD  SUBCASE.
This error occurs in DESOBJ 2.
I would like to know:
  1. How can I create alternating load steps to simulate the traction and compression phases
  2. If it is possible to run an optimization with these dynamic loads
Thank you !
1 - 6 of 61
