The problem consists of a connecting rod submitted to axial loads which define the phases of admission (traction) and combustion (compression).
I am trying to run the following optimization:
- 2 load steps :
- 2 responses :
- 1 constraint :
- 1 objective :
I managed to run a direct transient analysis for the two separate load cases.
I tried running a topology optimization for one of the load cases but an error occured with the following message:
*** ERROR # 557 *** DRESP1 2 is not referenced from within a static or an MBD SUBCASE.
This type of response must be specified from within a static or an MBD SUBCASE.
This error occurs in DESOBJ 2.
I would like to know:
- How can I create alternating load steps to simulate the traction and compression phases
- If it is possible to run an optimization with these dynamic loads
Thank you !
