"Reporting Extension
Hello!
If I use the Reporting Extension to build an HTML report and then write that report to the repository, can I then display that report by using RapidMiner Server?
I know RapidAnalytics has it's own reporting tool, but I'm just curious as I could then perhaps use it to display other HTML content.
Thanks,
JEdward.
Thanks,
JEdward.
1 - 2 of
21
My reasoning is that if I have an instance of RapidMiner server with named user access rights set onto certain processes (the ones that generate reports) then I just need one place to send those users to login, generate & view a report. RapidMiner.
I'm probably just not understanding the way webservers work properly, am I?
Why not using only a web server ?
Feeding a web server with static hmtl seems for me a convenient way.
