🎉Community Raffle - Win $25
Join and Win
[SOLVED]How to check the input Object Type?
User: "wujiang"
New Altair Community Member
Updated by Jocelyn
Hello,
-I have two output ports which contents "obj1 (obj1.class), obj2 (obj2.class)" for each as the release object.
-I have one input prot.
-What I want is checking the input object type when I get the Data form whatever which output port released.
obj1(output) \
                    ------- input port
obj2(output) /
I thought I can do like:
if(input.getData() instancof Obj1)
   do ....
But the "getData()" method was deprecated
I have to use "input.get(Obj1.class)" or"input.get(Obj2.class)"
If I do so, I think the way what I just proposed won't be work.
Could you help me?
Thanks
Jiang
1 - 2 of 21
    User: "Marco_Boeck"
    Hi,
    you can call "getAnyDataOrNull()" on the input port. You can then check what you got and deliver it to the desired output port.
    Regards,
    Marco
    User: "wujiang"
    OP
    Thanks Marco, It works fine.  ;D ;D ;D
