1 - 4 of
41
Dear friends
thank you Marius
i did classification by using stacking operator in offline mode .
now i want to make the same but in real time .
real time which controls an environment by receiving data, processing them, and returning the results sufficiently quickly to affect the environment at that time
my project detect DOS attacks in real time by using data mining . (online )
image link show (process of stacking done by rapidminer).
keep in touch
thank you friends
thank you Marius
keep in touch
thank you friends
Hi,
the X-Validation has a model output port. Store the resulting model via the Store operator to the repository.
Then create a new process. In the new process you can load the stored model using the Retrieve operator, and apply it to new data in the same way as in your testing process, i.e. with the Apply Model operator.
That helps you to apply the model in real time. Does that help?
Best regards,
Marius
Best regards,
Marius
hi every one, i need your help in my project and is to implement stacking operators in real time ,
the problem is i don't know how to start ,so i need your ideas and support to do this.i collected data and used rapidminer in offline mode .now i need to do the same work but in real time by using stacking .
i am waiting your help
majed
