Altair RISE
Nominate Yourself Now!
[Solved] Converting Numerical Values to Binomial
User: "neilduggan"
New Altair Community Member
Updated by Jocelyn
Hi
Very new user here so apologies if this questions seems dumb!!
I have some survey data with answers to each question as follows:
Yes = 1
No = 2
Undecided = 3
Refused to answer = 4
etc
I want to remove all values not equal to 1 or 2 or set it to "N/A" and then set values = 1 to "True" and set values = 2 to "False"
At the moment, I'm using "Generate Attributes" to create new attributes called "answer_yes" (answer==1) and "answer_no" (answer==2)
I presume there is a much better way to do this?? Or is this way as simple as any??
Any help appreciated :-)
Thanks
Neil
1 - 4 of 41
    User: "neilduggan"
    OP
    One other thing - I can't remove the rows containing the values 3 or 4 as these occur on different lines each time.
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    does each row only contain the answer to a single question? Is the anwer column nominal? f so, you can use the Filter Examples operator to get ride of rows where the value is not 1 or 2. Then you can use Generate Attributes (on the very same answer column, the operator can overwrite existing values) with this expression:
    if (Answer=="1", "true", "false")
    otherwise you can do
    if (Answer=="1", "true", if (Answer=="0", "false", NaN))
    Regards,
    Marco
    User: "neilduggan"
    OP
    Hi
    Thanks for your reponse Marco.
    Each row contains the answer the multiple questions (i.e. each column is a question and each row is a respondent)
    Each answer is nominal (i.e. 1, 2, 3, 4, etc) although is viewed by RapidMiner as numerical.
    I'll have a try when I get home and let you know how I got on
    Thanks
    User: "neilduggan"
    OP
    Thanks Marco, that second piece of code did the trick  :)
