🎉Community Raffle - Win $25
Join and Win
Tutorials not executing
leejaydUser: "leejayd"
New Altair Community Member
Updated by Jocelyn
Hi,
I'm very new to RapidMiner and was looking forward to stepping through the tutorials however, the first tutorial stops after the repository step. None of the other tutorials work.  I'm running version 6.0.002 on Win7.
Is anyone else experiencing this problem?
Lee :-\
1 - 10 of 101
    Hi,
    what exactly do you mean by "stopped"? After showing some introductory steps via a bubble the first comic step is activated which illustrates how to proceed.
    Are the bubbles shown when starting the first episode? Are the comics shown at all?
    Best,
    Nils
    OP
    After the second bubble appears (1st tutorial) talking about repository's no more bubbles appear when I select Next  I just get left at the repository screen.
    This is the expected behavior. Instead of the bubbles the comic (which is being displayed in the background) shows what to do next  ;)
    OP
    I found out the issue.  I had previously run one of the wizards and I think this may have changed the view.  Once I selected View : Restore Default Perspective the tutorial started working.
    Hi,
    thanks for letting us know about the issue! I have added it to our internal bug list.
    Regards,
    Marco
    Comic Strip Tutorial #4 Validation process does not advance  past the Testing Subroutine.  All operators are correct and connected.  When I hit RUN, the process executes correctly, but the tutorial will not advance and remains @ 50% complete.
    Hi,
    could you please copy&paste the xml (select "View" -> "Show Views" -> "XML" in the top menu bar) here? That step is a bit tricky  and I suspect that you are missing a connection in the subprocess.
    Regards,
    Marco
    Marco Boeck wrote:
    Hi,
    Regards,
    Marco
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.0.003">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="6.0.003" expanded="true" height="60" name="Retrieve Deals" width="90" x="45" y="30">
            <parameter key="repository_entry" value="//Samples/data/Deals"/>
          </operator>
          <operator activated="true" class="x_validation" compatibility="6.0.003" expanded="true" height="112" name="Validation" width="90" x="246" y="30">
              <operator activated="true" class="decision_tree" compatibility="6.0.003" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/>
              <connect from_port="training" to_op="Decision Tree" to_port="training set"/>
              <connect from_op="Decision Tree" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
              <portSpacing port="sink_model" spacing="0"/>
              <portSpacing port="sink_through 1" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="6.0.003" expanded="true" height="76" name="Apply Model" width="90" x="112" y="30">
              </operator>
              <operator activated="true" class="performance_classification" compatibility="6.0.003" expanded="true" height="76" name="Performance" width="90" x="380" y="120">
                <list key="class_weights"/>
              </operator>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="source_model" spacing="0"/>
              <portSpacing port="source_test set" spacing="0"/>
              <portSpacing port="source_through 1" spacing="0"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Retrieve Deals" from_port="output" to_op="Validation" to_port="training"/>
          <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Hi,
    you have added the "Performance (Classification)" operator instead of the "Performance" operator. I know the picture might be a bit confusing as of now :-\
    If you exchange this operator, it should work.
    Regards,
    Marco
    User error.  THANKS
