1 - 3 of
31
Thank you for your reply.
I used Set Rule operator to label one of the attributes (unless there is another way).
Now i'm trying to use the Weight by operator (by the way, there are plenty of t) but none of them works for me.
It says that the 'label must be nominal; and i don't understand why it's not working.
any idea?
any idea?
you can set one of them to label and use the weight by operators
~Martin
