🎉Community Raffle - Win $25
Join and Win
Relation between two columns
User: "sshilderman"
New Altair Community Member
Updated by Jocelyn
Hi all,
I have two column with numbers only.
I need to find a relation between those two.
For example: column B increasing only when column A decreasing.
Thanks a lot.
1 - 3 of 31
    Hi,
    you can set one of them to label and use the weight by operators
    ~Martin
    User: "sshilderman"
    OP
    Thank you for your reply.
    I used Set Rule operator to label one of the attributes (unless there is another way).
    Now i'm trying to use the Weight by operator (by the way, there are plenty of t) but none of them works for me.
    It says that the 'label must be nominal; and i don't understand why it's not working.
    any idea?
    Hi,
    you need to use a  measure which works for numerical values. e.g. Weight By Correlation.
    Best
    Martin
