"How to extract text from multiple webpages"
I like to extract text from blogs. I created a excelsheet with URL to blog and news pages. In rapidminer I use the "Get Pages" operator to extract the page content. At the moment I extract the content of the entire page and I just want extract the text of the blog.
Does anybody knows how to extract only text?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.0.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="6.0.002" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75">
<parameter key="excel_file" value="C:\Improve Your Business\Qing\Sales\Conquaestor\Links KLM.xlsx"/>
<parameter key="sheet_number" value="2"/>
<parameter key="imported_cell_range" value="A1:A2"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="Link.true.file_path.attribute"/>
</list>
</operator>
<operator activated="true" class="web:retrieve_webpages" compatibility="5.3.001" expanded="true" height="60" name="Get Pages" width="90" x="179" y="75">
<parameter key="link_attribute" value="Link"/>
<parameter key="follow_redirects" value="false"/>
</operator>
<operator activated="true" class="generate_id" compatibility="6.0.002" expanded="true" height="76" name="Generate ID" width="90" x="313" y="30"/>
<operator activated="true" class="text:data_to_documents" compatibility="5.3.002" expanded="true" height="60" name="Data to Documents" width="90" x="514" y="75">
<list key="specify_weights"/>
</operator>
<operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="94" name="Process Documents" width="90" x="179" y="210">
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="keep_text" value="true"/>
<operator activated="true" class="web:extract_html_text_content" compatibility="5.3.001" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="179" y="75"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="313" y="75"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="715" y="75">
<parameter key="min_chars" value="3"/>
</operator>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<connect from_op="Read Excel" from_port="output" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents" from_port="word list" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</list>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
