Morph elements and adapt surfaces
Altair Community Member
Updated by Casper Kruger
Hi,
I found the below link to a morphing question, but the link in the answer does not work.
How can I morph mesh on a surface and automatically update the surfaces associated with the morphed mesh?
Thank you,
1 - 2 of
21
OPUpdated by Casper Kruger
Hi Ben,
The link works, but I can not find the hm.zip or tube.hm file in the installation directory to run through the example. Any idea where teh example file is located in 2021.2 install?
Thank you,
Casper
https://2021.help.altair.com/2021/hwdesktop/hm/topics/tutorials/hm/hm_3600_morphing_tube_to_different_configurations_c.htm?zoom_highlightsub=hm-3600
Does that link work?
If you are trying to associate the mesh to the surface then the projection option should work.
