Altair RISE
Nominate Yourself Now!
Text analysis, word count
User: "dyna"
New Altair Community Member
Updated by Jocelyn
Hello,
I am trying to count the number of specific words in pdf files, which works fine in general (operator create document and process document to create the list of words I am looking for and operator process documents from files to read in the pdf files). But I have two specific questions/problems:
1. What do I have to do when I want that it does not only count the exact word but all words starting with the expression? For example: I want all words starting with "risk". So it should not only count the word "risk", but also "risks", "risky" and so on all together.
2. What do I have to do when I want that it counts two specific words in a row? For example: I want to count all occurences of "liquidity risk", not "liquidity" or "risk" alone. Also, then it shouldn't add this occurence of the term "risk" to the first search with all words starting with risks.
Thank you so much in advance for your help!!
1 - 27 of 271
    Hi,
    for 1: Have a look at Stem (Dictionary) - that should help.
    for 2: I guess a simple replace dictionary would do the trick? Otherwise i would recommend to use 2_grams.
    ~Martin
    User: "dyna"
    OP
    Hello,
    thank you very much for your quick and helpful response!
    Stem (Dictionary) really solved my first problem.
    But I am still having trouble with searching for two words in a row, even with 2_grams. Here again a concrete example: I am looking for the term reputation.* risk.* (reputational risk, reputational risks, reputation risk, reputational risks). So I create a document with the words "reputation" and "risk", process it (tokenize, transform cases and generate n-grams). Then I process the pdf-files (tokenize, transform cases, generate n-grams and stem (dictionary) so that everything starting with reputation is reduced to reputation and everything starting with risk is reduced to risk). But the problem now is that the output shows me 0 counts for "reputation risk", the counts for "reputation" and "risk" alone work, though.
    Do you have any suggestions how I can alter/fix the process so that it shows me the right number for "reputation.* risk.*"?
    Thank you so much for your efforts!
    Hi,
    sorry i only have time for a quick note: Have you had a look on Extract Information?
    ~Martin
    User: "JEdward"
    What order do you have them in?
    tokenize, transform cases, generate n-grams and stem (dictionary) ?
    Shouldn't it really be
    tokenize, transform cases, generate stem (dictionary)and n-grams because you want to stem first and then create the n-grams?
    User: "rajbanokhan"
    hi,
    i have issues in word counting, when process the text some words are like
    aaaaa
    aaaaaa
    aaaeee
    aaahh
    aachen
    aamcgol
    aanda
    aandm
    how can i remove  it
    User: "sgenzer"
    Altair Employee
    hello @rajbanokhan - can you please post your XML process so we can see?  Please see "READ BEFORE POSTING" pane on the right hand side of your Reply window for instructions.
    Scott
    User: "Thomas_Ott"
    It might be related to Pruning. Do you have any pruning turned on? That usually gets rid of weird stuff like that. Pruning is a parameter setting on the Process Documents from... operator.
    User: "rajbanokhan"
    i dont know about pruning but i use these steps
    Tokenize Nonletters (Tokenize)
     Tokenize Linguistic (Tokenize)
     Filter Stopwords (English)
     Filter Tokens (by Length)
     Stem (Porter)
     Transform Cases
    User: "Thomas_Ott"
    Pruning is available via the Process Documents from Data operator. Your Tokenize, Stem, etc should all be inside that subprocess.
    User: "rajbanokhan"
    yes i apply prune method and its work thank you so much
    User: "Thomas_Ott"
    Awesome! Now if you could Accept my suggestion as the solution I'd be super happy!
    User: "rajbanokhan"
    hi i am doing textmining i want the most frequent word value come first. like if
    banana occurences 10 and car occurence is 8 then it come like
    banana 10
    car         8
    how to count from higher to lower
    User: "kayman"
    If you use the wordlist to data operator your list becomes an example set, and then you can use the sort and filter operators.
    User: "rajbanokhan"
    hi
    i am using sort technique for sorting but in attribute names the options are
    label
    meta data date
    meta data file
    meta data path
    i select label option but i am not get the sorting data or you can say most frequent value
    User: "rajbanokhan"
    hi
    when i used wordlist to data then i use sort operator the parameter "attribute names" were not show their options
    so thats why i only use process documents from files and sort but sort doesnt sort my data
    User: "rajbanokhan"
    hi
    i am doing textmining. i use process document from files operator. when i run the process it gives me a list of words but i dont want the whole list of words. i just want select my own words from the list which i want. suppose i want words cat, dog, mouse, table chair. how can i get these words only these words from list.
    Hi,
    have a look at the "Filter Tokens Using Example Set" operator of operator toolbox. This should do the trick.
    Cheers,
    Martin
    User: "rajbanokhan"
    hi
    thank you to focus on my question.
    but i dont get the operator .
    is this an filter example operator or filter tokens (by content) can you guide me because filter example is not working it show empty (no words are show)
    i use both one by one and filter tokens by content work. and thanks again for
    Hi,
    did you install operator toolbox extension?
    BR,
    Martin
    User: "rajbanokhan"
    hi sir
    i install textmining extension and i didnt find this extension in searching of extension in marketplace
    User: "rajbanokhan"
    hi didnt find operator tool box extension
    User: "sgenzer"
    Altair Employee
    hello @rajbanokhan so both of those extensions can be found in the marketplace. If you open RapidMiner Studio, you should see a menu at the top called "Extensions". Choose the first item "Marketplace (Updates and Extensions)... Then search for "Text Processing" and "Operator Toolbox".
    Scott
    User: "rajbanokhan"
    hi
    how i find or count the total number of words in one document and then in second and then third and so on?
    User: "sgenzer"
    Altair Employee
    hi @rajbanokhan - very easy to count tokens. See the attached process and image below.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.003">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="34">
            <parameter key="text" value="hi how i find or count the total number of words in one document and then in second and then third and so on?"/>
          </operator>
          <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34"/>
          <operator activated="true" class="text:extract_token_number" compatibility="8.1.000" expanded="true" height="68" name="Extract Token Number" width="90" x="313" y="34"/>
          <connect from_op="Create Document" from_port="output" to_op="Tokenize" to_port="document"/>
          <connect from_op="Tokenize" from_port="document" to_op="Extract Token Number" to_port="document"/>
          <connect from_op="Extract Token Number" from_port="document" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Scott
    User: "rajbanokhan"
    hi sir
    thank you for your response.
    i am using process documents files. it has only one folder and inside folder there are seven pdf files now can you tell me how total words count from each or all.
    User: "sgenzer"
    Altair Employee
    can you please post your xml?
    User: "Telcontar120"
    The token number can be saved as part of the metadata output from Process Documents (see screenshot above) by selecting the "add meta information" option, which then adds token number as an attribute.
