This process loads numerical data from file and generates some attributes with the feature generation operator. The parameter list "functions" of the generation operator must be edited in order to define the functions which should be generated. Try the following: Start the process. Use breakpoints to check the generation step. The parameter "keep_all" defines if all attributes should be used for the result example set or only the newly generated ones. Edit the parameter list "functions" and add some other functions. Most of the known mathematical functions can be used.
