1 - 8 of
81
Hi,
RapidMiner Studio stores settings in a custom folder in the user folder of your operating system. So for example on Windows "C:\users\username" is the user folder, and in there is a subfolder called ".RapidMiner" or ".RapidMiner5" (depends on the version you are running). In there either rapidminer-studio.log or rm.log can be found, which might give me a clue what went wrong.
Regards,
Marco
Regards,
Marco
here it is (rapidminer-studio.log) ... i found nothing related
Jan 23, 2014 9:07:50 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Jan 23, 2014 9:07:50 PM com.rapidminer.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Jan 23, 2014 9:07:50 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Data Editor
Jan 23, 2014 9:07:52 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Jan 23, 2014 9:08:19 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Jan 23, 2014 9:08:19 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
Jan 23, 2014 9:08:41 PM com.rapidminer.gui.ApplicationPerspectives loadAll
CONFIG: Loading perspectives.
Jan 23, 2014 9:08:58 PM com.rapid_i.deployment.update.client.UpdateManager checkForUpdates
CONFIG: Ignoring update check. Last update check was on 1/23/14 7:20 PM.
Jan 23, 2014 9:10:32 PM com.rapidminer.operator.nio.model.WizardState readNow
INFO: Reading example set...
Jan 23, 2014 9:12:06 PM com.rapidminer.operator.nio.model.WizardState readNow
Jan 23, 2014 9:33:20 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
INFO: Running shutdown sequence.
Jan 23, 2014 9:33:20 PM com.rapidminer.gui.ApplicationPerspectives saveAll
CONFIG: Saving perspectives.
Jan 23, 2014 9:33:20 PM com.rapidminer.tools.usagestats.UsageStatistics save
CONFIG: Saving operator usage.
4_0.3_0.7_2000_2_-6_-19_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-2_-19_0.8,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_3_-6_-38_1.4,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_2_-19_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-2_-38_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_2_-38_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-2_-19_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-6_-38_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_6_-19_0.8,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-6_-38_1.4,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_2_-38_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-6_-19_1.4,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-2_-38_0.8,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-6_-19_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-2_-38_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-6_-38_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_-6_-38_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_6_-38_1.1,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-6_-38_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_3_2_-19_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_4_2_-38_1.4,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_-2_-19_1.4,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_3_2_-38_0.5,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
4_0.3_0.7_2000_2_6_-38_0.8,02/01/2013 09:35,BUY,1,1450.25,,,2013-01-02,09:35
Hi,
sorry for the delay, your answer slipped by!
This works for me just fine when selecting "," as the separator. See the process below (you just need to adapt the location of the .csv file):
Marco
Regards,
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.0.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="6.0.002" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="csv_file" value="C:\Users\username\Desktop\test.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="date_format" value="yyyy-MM-dd:HH:mm"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="encoding" value="UTF-8"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="att1.true.polynominal.attribute"/>
<parameter key="1" value="att2.true.binominal.attribute"/>
<parameter key="2" value="att3.true.binominal.attribute"/>
<parameter key="3" value="att4.true.integer.attribute"/>
<parameter key="4" value="att5.true.real.attribute"/>
<parameter key="5" value="att6.true.attribute_value.attribute"/>
<parameter key="6" value="att7.true.attribute_value.attribute"/>
<parameter key="7" value="att8.true.binominal.attribute"/>
<parameter key="8" value="att9.true.binominal.attribute"/>
</list>
</operator>
<operator activated="true" class="nominal_to_date" compatibility="6.0.002" expanded="true" height="76" name="Nominal to Date" width="90" x="179" y="30">
<parameter key="attribute_name" value="att8"/>
<parameter key="date_format" value="yyyy-MM-dd"/>
</operator>
<operator activated="true" class="nominal_to_date" compatibility="6.0.002" expanded="true" height="76" name="Nominal to Date (2)" width="90" x="313" y="30">
<parameter key="attribute_name" value="att9"/>
<parameter key="date_type" value="time"/>
<parameter key="date_format" value="HH:mm"/>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
<connect from_op="Nominal to Date" from_port="example set output" to_op="Nominal to Date (2)" to_port="example set input"/>
<connect from_op="Nominal to Date (2)" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
Marco
does the preview in the import wizard show the correct data structured in a table? You need to set some parameters during import to match your actual .csv file structure.
You can check the rapidminer-studio.log / rm.log file in the .RapidMiner / .RapidMiner5 folder in your user home to see if any errors appear after importing.
Regards,
Marco
