Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
[SOLVED] Remove duplicates selecting which examples must remain
arthurgouveia
Hello.
I have a large customer dataset with some values "duplicate". Let me try to make myself clear: I have a dataset with over 50 attributes of over 200k contracts. One of these attributes is
contract_status
. Some of these statuses are valid and some are invalid. I've created a boolean attribute named
is_valid_status
I'd like to remove duplicates based on a subset of attributes and keep only the examples where
is_valid_status
is true.
How can I do it?
Thanks
AI Studio
Accepted answers
All comments
RalfKlinkenberg
Hello Arthur Gouveia,
you can use the RapidMiner operator called
Filter Examples
Cheers,
Ralf
MariusHelf
Hi Arthur,
in addition to Filter Examples for filtering on is_valid_status you can use the Remove Duplicates operator. It allows to select which attributes are considered for finding duplicates. You should try the operators first on a smaller subset to get a feeling for their settings.
Best regards,
Marius
arthurgouveia
Thank you! It worked almost perfectly. I can't believe I didn't think about the solution you guys gave me.... ::)
But now I have another problem. I found several contracts with valid statuses and I'd like to remove duplicates but keep only the most recent status. I have an attribute named date_processing that I can use to achieve that but I can't figure how.
Is there any way to remove duplicates keeping only the most recent data?
RalfKlinkenberg
this requires several steps:
You can use the RapidMiner operator
Aggregate
to determine the
maximum
of
date_processing
for each client (group by client ID).
The operator
Rename
can be used to rename the new attribute
max(date_processing)
to
max_date
With
Join
you can add the
max_date
column to the original data table (select the client ID as ID for both tables).
With
Filter Examples
you keep only the data lines where
date_processing
max_date
and you are done.
Cheers,
Ralf
arthurgouveia
It didn't work. Almost everything went ok but I couldn't filter just the max_date. It cannot parse value 'max_date' with date pattern yyyy-MM-dd HH:mm:ss Z
What is amazing is that when I look to the meta data view the max_date attribute is type date_time. I've tried to change the type using Date to Nominal, Date to Numerical, Numerical to Date, Nominal to Date, Guess Types but all of them either don't list max_date at the attribute list or don't make Filter Example work.
arthurgouveia
I found a solution! I used the Generate Attributes to create a date_dif attribute using the function
date_diff(max_date,date_processing)
. Then I just had to filter the examples where date_dif=0.
It's working! Thanks!
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
