Altair RISE
Nominate Yourself Now!
Export "Data To Similarity" results to a CSV
User: "ClaraCaba"
New Altair Community Member
Updated by Jocelyn
Hi!
I am working with text mining in Rapidminer and the following problem has arised:
I use the Data to Similarity operator from the Text Extension and the "sim" output port gives a table with three columns: one object, another object, and the similarity between them. However, I can't sort or export that result, which I'd love to do, in order to be able to work with that data as a CSV file.
Is there any way to export that table?
Thank you very much!
1 - 9 of 91
    Hi,
    you can take Similarity to Data to get an Example Set out of it. Afterwards you can store it with any Write operator.
    ~Martin
    User: "ClaraCaba"
    OP
    Thank you very much, that worked perfectly.
    I am facing now another problem, though.
    After using the Similarity to Data operator, I have a dataset with three columns: the first id used for comparison, the second id used for comparison, and the similarity percentage. Now, I would like to combine that information with my original database (which has many attributes). I don't know how to, for example, obtain the rows from my original database where the similarity percentage is greater than 50%. Any idea?
    Thank you in advance.
    Hi,
    Use a Filter Examples to delete the examples< 0.5. Afterwards you can join the original data. If you do not have an ID in the dataset, you can use GenerateID before hand to add one.
    ~Martin
    User: "ClaraCaba"
    OP
    Hi,
    However, I have a last question. I have applied Data to Similarity and then Similarity to Data right after, to be able to use the output dataset. But the dataset contains all results duplicated, since I have applied both operators. How could I prevent this from happening? Or how could I get rid of the duplicated results and just keep a row per similarity between two objects?
    Thank you.
    Hi,
    a general idea is to use Cross Distance, it is a bit more flexible.
    For your question:
    Do i understand it correctly, that you have the distance twice in like this
    ID1  ID2  SIM
    2      1      0.5
    1      2      0.5
    My first idea would be to create a new ID with the Two IDs you have. I would always take the smaller one first. So you always get a string like
    SmallNumber _ BigNumber
    This results in this:
    if([FIRST_ID]>[SECOND_ID],
    concat(str([FIRST_ID]),"_",str([SECOND_ID])),
    concat(str([SECOND_ID]),"_",str([FIRST_ID]))
    Afterwards you can use Remove Duplicates on this. See attached Process
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="7.0.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="7.0.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="112" y="34">
            <parameter key="repository_entry" value="//Samples/data/Golf"/>
          </operator>
          <operator activated="true" class="data_to_similarity" compatibility="7.0.001" expanded="true" height="82" name="Data to Similarity" width="90" x="246" y="34"/>
          <operator activated="true" class="similarity_to_data" compatibility="7.0.001" expanded="true" height="82" name="Similarity to Data" width="90" x="380" y="34"/>
          <operator activated="true" class="generate_attributes" compatibility="7.0.001" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="34">
            <list key="function_descriptions">
              <parameter key="IdToRemoveDuplicates" value="if([FIRST_ID]&gt;[SECOND_ID],&#10;&#9;concat(str([FIRST_ID]),&quot;_&quot;,str([SECOND_ID])),&#10;&#9;concat(str([SECOND_ID]),&quot;_&quot;,str([FIRST_ID]))&#10;)"/>
            </list>
            <description align="center" color="transparent" colored="false" width="126">Create an ID to remove the stuff</description>
          </operator>
          <operator activated="true" class="remove_duplicates" compatibility="7.0.001" expanded="true" height="82" name="Remove Duplicates" width="90" x="648" y="34">
            <parameter key="attribute_filter_type" value="single"/>
            <parameter key="attribute" value="IdToRemoveDuplicates"/>
          </operator>
          <connect from_op="Retrieve Golf" from_port="output" to_op="Data to Similarity" to_port="example set"/>
          <connect from_op="Data to Similarity" from_port="similarity" to_op="Similarity to Data" to_port="similarity"/>
          <connect from_op="Data to Similarity" from_port="example set" to_op="Similarity to Data" to_port="exampleSet"/>
          <connect from_op="Similarity to Data" from_port="exampleSet" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Remove Duplicates" to_port="example set input"/>
          <connect from_op="Remove Duplicates" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "ClaraCaba"
    OP
    Thank you very very very much!!! :D
    That worked perfectly.
    User: "sangeet171188"
    And how to get count of similar looking sets( Text field). For the below set I want count like
    ABC is good text -----3
    XYZ is great -----------2
    FIRST SECOND SIMILARITY textfield
    1               2                    1           ABC is a good text
    3                8                    1           ABC is a good text
    4                9                      1          ABC is a good text
    12              32                    1            XYZ is great
    31              77                    1            XYZ is great
    User: "Thomas_Ott"
    Can't you use an Aggregate operator for this?
    Thanks Thomas. Results achieved.
