Altair RISE
Nominate Yourself Now!
(SOLVED) help installing rapidminer server
User: "inceptorfull"
New Altair Community Member
Updated by Jocelyn
I tried to install rapidminer server it give me at the end
"Service.bat terminated abormally error code : 9.009- rapidminer server service registration may have failed"
although I test the MYsql connection and it worked.
tried to open the rapidminer server
http://koana:8080/
it gives me  white page only
and when try to run the standalone
14:54:49,416 INFO  [org.jboss.as] (Controller Boot Thread) JBAS015954: Admin console is not enabled
14:54:49,417 ERROR [org.jboss.as] (Controller Boot Thread) JBAS015875: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" started (with errors) in 198478ms - Started 1113 of 1198 services (1 services failed or missing dependencies, 82 services are passive or on-demand)
can anyone help me what to do to make it works?
1 - 10 of 101
    Hi,
    Question 1)
    to install it as a service, you need to start the installer with admin privileges. Otherwise Windows will prevent it.
    However you can still start it via the standalone.bat file manually.
    Question 2)
    Obviously I cannot see the entire log, but at that point http://koana:8080/ should work. The part where it says "started (with errors)" can usually be ignored because nothing is actually wrong.
    Regards,
    Marco
    OP
    thanks for reply
    but it doesnot work and give me blank page so what may be the problem? also i canot find RM services in windows services
    any help?
    OP
    when I re installted it using run as adminstrator , although I got the same error but it worked thanks
    User: "JEdward"
    Hey glad to know you got it up and running.  I recommend having a look at the RapidMiner Youtube account.  There's a series of Youtube videos that guide you through setting up webapps from your RapidMiner Processes.
    That should get you started quickly.
    User: "sgenzer"
    Altair Employee
    hi...I'm trying to install a RM Server on a Mac Pro and am getting the same issue - looks like RM Server is running but I get a blank page on the browser.  I have tried several different ways and still get the same result.  The previous comment does not help me (I don't think?) because I am using Mac OS where I am already logged in as administrator...
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    what does the log file say (found in SERVER/standalone/logs/server.log)?
    Regards,
    Marco
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    looks like your database configuration is incomplete, it complains that it does not know which database to use. Maybe you forgot to add the schema?
    Can you post the contents of the relevant <datasource> section?
    Regards,
    Marco
    User: "sgenzer"
    Altair Employee
    ok that's an interesting point.  When I was installing RM Server, I left schema blank and only then did the "Test Connection" say that everything was ok.  I take it that this was NOT ok?
    I am NOT a SQL person so I just tried to follow the instructions as best as I could on SQL Workbench and hope for the best.  :)
    Scott
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    this depends on the database system. Oracle is for example fine (or even required) to leave blank. Others require a schema. I dunno why the test succeeded but Server fails though. Probably our test does not cover the entirety of what Server itself needs to do..
    Regards,
    Marco
