🎉Community Raffle - Win $25
Join and Win
"Operators missing after adding extension in rapid analytics"
User: "jprakash0205"
New Altair Community Member
Updated by Jocelyn
Hi,
I have installed extensions in Rapid Analytics server. I followed the below steps..
1. Set the system property com.rapidanalytics.plugins to /opt/rapid/plugins (path in my machine)
2. copy the extensions into that directory /opt/rapid/plugins
3. restart the server
After that i am not able to see the Operators in the Operators Tab.. if i remove plugin path in the system property and restart the server, i am able to see the operators.
Pls advise us.
thanks,
JP
1 - 2 of 21
    User: "MariusHelf"
    Hi JP,
    are you talking about the operators from the plugin only, or is the Operators Tab completely empty if you set the property?
    Best regards,
    Marius
    OP
    Hi Marius,
    I mean the Operators Tab which is completely empty..after setting the property com.rapidanalytics.plugins, copied the extensions to plugin folder and restarted the server.
    I appreciate any help..
    Thanks,
    JP
