ETL standard text modification
Hello
What are the options for preparing a dataset within Rapidminer Studio when it comes to string attributes ?.
I know I can split and Combine, but is there a way to remove White space, transform into upper lower or capital case etc, with and without generating a new attribute. Is there a dedicated Operator for this or do I have to use the Script Operator ?
I there an other Operator showing pre build function or any kind of help when comming to scripting, maccros, or regular expressions ?
thanks ;D
thanks ;D
