This is an embed external element. It can be deleted using the delete key or the backspace key. To view the full element, press the preview button below.
Yubuchi-san,
The issue you have found will be fixed with Activate 2022.2 (coming soon!).
In the meantime just a small modification of the model helps to run it (similar to the Spice model):
Hope that helps.
