Altair RISE
Nominate Yourself Now!
how to export results in tabular form? and edit AUC graph
User: "inceptorfull"
New Altair Community Member
Updated by Jocelyn
hi all
I want to export the results in tabular form for academic purpose so how to do it?
plus I want to change the AUC graph instead of lines to be bars
1 - 2 of 21
    User: "DocMusher"
    Hi,
    You can write the results to a csv or other format.
    What would be the advantage to use bars for an AUC graph?
    Cheers
    Sven
    OP
    thanks for reply, I will try it, but I am now stoped at stage , to get the best attribuets using Genetic Algorithm (optimization selection) .
    Am comparing the results of log with neural network, but i have 37 dataset input and want to reduce it, by GA , but it need a model to apply inside it
    so do I use GA two times? one with log and another one with NN?
    but I want  a Common reduced set of attributes , to be the input for LOG and NN is there a way to do it? is there a model I can apply work well with GA?
