🎉Community Raffle - Win $25
Join and Win
"Please help me to use web mining and clawling"
ezouliasUser: "ezoulias"
New Altair Community Member
Updated by Jocelyn
Dear friends,
I have a problem with web mining and clawling.
Although I see that Web Mining Extension is downloaded and installed. I can not find the Web Mining folder under the Operators sections to select the  Crawl Web or other operators.
Best regards,
manols
1 - 9 of 91
    Hi,
    how did you install the Web extension? How did you check that it has been installed?
    Best regards,
    Marius
    Hi,
    I installed via Help -> Updates and Extensions -> Updates.
    I checked that it is installed via Help -> Manage Extensions.
    Thank you in advance
    Manolis
    Hi,
    can you post the contents of the rapidminerm-studio.log (or rm.log for RM 5)? You can find it inside the USER folder on your OS in the .RapidMiner (.RapidMiner5) subfolder.
    Regards,
    Marco
    I found two files rm.log and rm.log.1.
    Each of them exceeds the 20000 characters.
    I sent you both into different posts
    rm.log part 1/2
    Jan 12, 2014 9:28:38 AM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Jan 12, 2014 9:28:40 AM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: QuantX-1 Extension
    INFO: Register plugin: Reporting
    INFO: Register plugin: Anomaly Detection
    INFO: Register plugin: Text Processing
    INFO: Register plugin: Parallel Processing
    INFO: Register plugin: LifeStyle Marketing
    INFO: Register plugin: R Extension
    INFO: Register plugin: Feature-Selection-Extension
    INFO: Register plugin: PRules
    INFO: Register plugin: semweb
    INFO: Register plugin: recommenders
    INFO: Register plugin: PMML
    INFO: Register plugin: WordNet
    INFO: Register plugin: Tacl
    INFO: Register plugin: MLWizard
    INFO: Register plugin: Web Mining
    INFO: Register plugin: Series
    INFO: Register plugin: SOM
    INFO: Register plugin: Intelligent Discovery Assistant
    INFO: Register plugin: Weka
    INFO: Register plugin: Ontological Extension for RM
    INFO: Register plugin: Extension Development
    INFO: Register plugin: Community
    INFO: Register plugin: WhiBo
    INFO: Register plugin: ImageMiner
    Jan 12, 2014 9:28:41 AM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
    WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsReporting, locale en
    at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
    at java.util.ResourceBundle.getBundleImpl(Unknown Source)
    at java.util.ResourceBundle.getBundle(Unknown Source)
    at com.rapidminer.tools.plugin.Plugin.registerDescriptions(Plugin.java:500)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginDescriptions(Plugin.java:738)
    at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:982)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:521)
    at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:240)
    at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:559)
    at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:540)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.rapid_i.Launcher.main(Launcher.java:367)
    WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsR, locale en
    Jan 12, 2014 9:28:42 AM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
    WARNING: Error initializing plugin: java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/ErrorsWeb, locale en
    Jan 12, 2014 9:28:43 AM com.rapidminer.tools.ClassColorMap parseKey
    SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.gdt_operators.whibo_gdt_evolutionary_search
    SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.validation.5x2_xvalidation_ftest
    SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.gdt_operators.gdt_algorithm
    SEVERE: Unknwon IO class: com.rapidminer.operator.whibo.validation.xvalidation_with_log
    Jan 12, 2014 9:28:43 AM com.rapidminer.tools.plugin.Plugin callInitMethod
    WARNING: Plugin initializer com.rapidminer.ParallelPluginInit.initPlugin of Plugin Parallel Processing caused an error: null
    java.lang.reflect.InvocationTargetException
    at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:896)
    at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:869)
    at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:849)
    at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:984)
    Caused by: java.lang.NoClassDefFoundError: com/rapidminer/operator/executor/ParallelUnitExecutorFactory$1
    at com.rapidminer.operator.executor.ParallelUnitExecutorFactory.install(ParallelUnitExecutorFactory.java:50)
    at com.rapidminer.ParallelPluginInit.initPlugin(ParallelPluginInit.java:40)
    ... 17 more
    Caused by: java.lang.ClassNotFoundException: com.rapidminer.operator.executor.ParallelUnitExecutorFactory$1
    at java.net.URLClassLoader$1.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(Unknown Source)
    at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLoader.java:102)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    ... 19 more
    Jan 12, 2014 9:28:45 AM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    INFO: Default version of expression parser registered successfully
    Jan 12, 2014 9:28:50 AM com.rapidminer.parameter.ParameterTypePassword decryptPassword
    WARNING: Password in XML file looks like unencrypted plain text.
    Jan 12, 2014 9:28:51 AM com.rapidminer.tools.OperatorService init
    INFO: Loading additional operators specified by rapidminer.operators.additional (${RAPIDMINER_OPERATORS_ADDITIONAL})
    SEVERE: Cannot find operator description file ${RAPIDMINER_OPERATORS_ADDITIONAL}.
    Jan 12, 2014 9:28:52 AM com.rapidminer.tools.math.similarity.DistanceMeasureHelper updateMeasure
    WARNING: While updating distance measure: com.rapidminer.parameter.UndefinedParameterError: A value for the parameter 'measure_types' must be specified! Expected integer but found 'null'.
    Jan 12, 2014 9:28:57 AM com.rapidminer.tools.plugin.Plugin registerOperators
    INFO: No operator descriptor specified for plugin Community. Trying plugin initializtation class com.rapidminer.community.CommunityPluginInit.
    WARNING: No operator descriptor defined for: Community
    Jan 12, 2014 9:28:57 AM com.rapidminer.operator.ExecutionUnit <init>
    WARNING: Process name does not follow naming conventions: Evolutionary search on WhiBo (in WhiBo GDT Evolutionary Search)
    Jan 12, 2014 9:28:58 AM com.rapidminer.tools.OperatorService init
    INFO: Number of registered operator classes: 936; number of registered operator descriptions: 1,062; number of replacements: 577
    Jan 12, 2014 9:28:59 AM com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    Jan 12, 2014 9:28:59 AM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    Jan 12, 2014 9:29:09 AM com.rapidminer.gui.ApplicationPerspectives loadAll
    CONFIG: Loading perspectives.
    Jan 12, 2014 9:29:09 AM com.rapidminer.elico.ida.IDAPluginInit initGui
    INFO: Initializing IDA GUI
    Jan 12, 2014 9:29:09 AM com.rapidminer.elico.ida.gui.dockable.WelcomeStep whitify
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@c42548,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import Excel Sheet...,defaultCapable=true]
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@c42548,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import CSV File...,defaultCapable=true]
    INFO: Whitify com.rapidminer.gui.tools.ExtendedHTMLJEditorPane[,0,0,0x0,invalid,layout=javax.swing.plaf.basic.BasicTextUI$UpdateHandler,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.basic.BasicBorders$MarginBorder@a62825,flags=296,maximumSize=,minimumSize=,preferredSize=,caretColor=javax.swing.plaf.ColorUIResource[r=0,g=25,b=100],disabledTextColor=javax.swing.plaf.ColorUIResource[r=180,g=180,b=180],editable=false,margin=javax.swing.plaf.InsetsUIResource[top=4,left=6,bottom=4,right=6],selectedTextColor=javax.swing.plaf.ColorUIResource[r=255,g=255,b=255],selectionColor=javax.swing.plaf.ColorUIResource[r=150,g=150,b=170],kit=com.rapidminer.gui.tools.ExtendedHTMLEditorKit@16baee0,typeHandlers=]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=8388608,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    INFO: Whitify javax.swing.Box[,0,0,0x0,invalid,layout=javax.swing.BoxLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@ccb3a6,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=java.awt.Dimension[width=400,height=200],preferredSize=java.awt.Dimension[width=400,height=200],defaultIcon=,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=Drop data here,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=8,height=32767],minimumSize=java.awt.Dimension[width=8,height=0],preferredSize=java.awt.Dimension[width=8,height=0]]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@1268e11,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=32767,height=0],minimumSize=java.awt.Dimension[width=0,height=0],preferredSize=java.awt.Dimension[width=0,height=0]]
    rm.log part 2/2
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=200,height=200],minimumSize=java.awt.Dimension[width=200,height=200],preferredSize=java.awt.Dimension[width=200,height=200],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=5,height=32767],minimumSize=java.awt.Dimension[width=5,height=0],preferredSize=java.awt.Dimension[width=5,height=0]]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.EmptyBorder@1ae7355,flags=9,maximumSize=java.awt.Dimension[width=620,height=1000],minimumSize=java.awt.Dimension[width=620,height=80],preferredSize=java.awt.Dimension[width=620,height=210]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.JLabel[,0,0,0x0,invalid,hidden,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/16/error.png,disabledIcon=,horizontalAlignment=LEADING,horizontalTextPosition=TRAILING,iconTextGap=4,labelFor=,text=,verticalAlignment=CENTER,verticalTextPosition=CENTER]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=350,height=250],minimumSize=java.awt.Dimension[width=350,height=100],preferredSize=java.awt.Dimension[width=350,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.Box$Filler[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=java.awt.Dimension[width=10,height=32767],minimumSize=java.awt.Dimension[width=10,height=0],preferredSize=java.awt.Dimension[width=10,height=0]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@17cc9f3,flags=328,maximumSize=java.awt.Dimension[width=500,height=250],minimumSize=java.awt.Dimension[width=500,height=100],preferredSize=java.awt.Dimension[width=500,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    Jan 12, 2014 9:29:10 AM com.rapidminer.elico.ida.installer.InstallerUtils readCurrentVersion
    INFO: Current IDA version is 01.023
    Jan 12, 2014 9:29:11 AM com.rapidminer.elico.ida.installer.IDAUpdater checkForUpdateNow
    INFO: IDA is up to date.
    Jan 12, 2014 9:29:11 AM com.rapidminer.io.community.MyExperimentConnection connectTo
    INFO: Connecting to: http://www.myexperiment.org/search.xml?num=100&;query=kind%3A%28RapidMiner%29&type=workflow
    Jan 12, 2014 9:29:12 AM com.rapidminer.gui.security.Wallet readCache
    CONFIG: Reading secrets file.
    Jan 12, 2014 9:29:13 AM com.rapid_i.deployment.update.client.UpdateManager$3 run
    INFO: Checking for updates.
    Jan 12, 2014 9:29:16 AM com.rapid_i.deployment.update.client.UpdateManager$3 run
    INFO: No updates since 1/9/14 5:40 PM.
    Jan 12, 2014 9:35:49 AM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
    INFO: Running shutdown sequence.
    Jan 12, 2014 9:35:49 AM com.rapidminer.gui.ApplicationPerspectives saveAll
    CONFIG: Saving perspectives.
    Jan 12, 2014 9:35:49 AM com.rapidminer.tools.usagestats.UsageStatistics save
    CONFIG: Saving operator usage.
    WARNING: Cannot save operator usage statistics: org.w3c.dom.DOMException: INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified.
    at com.sun.org.apache.xerces.internal.dom.CoreDocumentImpl.createElement(Unknown Source)
    at com.rapidminer.tools.usagestats.OperatorUsageStatistics.getXML(OperatorUsageStatistics.java:67)
    at com.rapidminer.tools.usagestats.UsageStatistics.getXML(UsageStatistics.java:283)
    at com.rapidminer.tools.usagestats.UsageStatistics.save(UsageStatistics.java:296)
    at com.rapidminer.gui.RapidMinerGUI$ShutdownHook.run(RapidMinerGUI.java:216)
    at com.rapidminer.RapidMiner.quit(RapidMiner.java:760)
    at com.rapidminer.gui.MainFrame.exit(MainFrame.java:1566)
    at com.rapidminer.gui.MainFrame.windowClosing(MainFrame.java:1597)
    at java.awt.AWTEventMulticaster.windowClosing(Unknown Source)
    at java.awt.Window.processWindowEvent(Unknown Source)
    at javax.swing.JFrame.processWindowEvent(Unknown Source)
    at java.awt.Window.processEvent(Unknown Source)
    at java.awt.Component.dispatchEventImpl(Unknown Source)
    at java.awt.Container.dispatchEventImpl(Unknown Source)
    at java.awt.Window.dispatchEventImpl(Unknown Source)
    at java.awt.Component.dispatchEvent(Unknown Source)
    at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.access$200(Unknown Source)
    at java.awt.EventQueue$3.run(Unknown Source)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
    at java.awt.EventQueue$4.run(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    end of rm.log
    rm.log.1 part 1/2
    Οκτ 30, 2013 10:41:50 ΜΜ com.rapidminer.RapidMiner performFirstInitialization
    INFO: Performing upgrade  from version 5.3.008 to version 5.3.013
    Oct 30, 2013 10:41:50 PM com.rapidminer.tools.I18N <clinit>
    Oct 30, 2013 10:42:02 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Information-Extraction
    Oct 30, 2013 10:42:08 PM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
    at com.rapidminer.tools.plugin.Plugin.registerDescriptions(Plugin.java:501)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginDescriptions(Plugin.java:739)
    at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:983)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:550)
    at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:241)
    at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:560)
    at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:541)
    at com.rapid_i.Launcher.main(Launcher.java:346)
    Oct 30, 2013 10:42:09 PM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
    Oct 30, 2013 10:42:11 PM com.rapidminer.tools.plugin.Plugin callInitMethod
    at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:897)
    at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:870)
    at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:850)
    at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:985)
    ... 17 more
    ... 19 more
    Oct 30, 2013 10:42:24 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    Oct 30, 2013 10:42:34 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
    Oct 30, 2013 10:42:39 PM com.rapidminer.tools.OperatorService init
    Oct 30, 2013 10:42:39 PM com.rapidminer.tools.math.similarity.DistanceMeasureHelper updateMeasure
    Oct 30, 2013 10:42:41 PM com.rapidminer.tools.OperatorService parseOperators
    WARNING: Cannot create operator description: rmx_information_extraction : binary_kernel_naiveBayes_operator
    java.lang.ClassNotFoundException: com.rapidminer.operator.learner.bayes.BinaryTreeKernelNaiveBayes
    at java.lang.Class.forName0(Native Method)
    at java.lang.Class.forName(Unknown Source)
    at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:93)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:300)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:293)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:269)
    at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:231)
    at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:484)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:808)
    at com.rapidminer.tools.OperatorService.init(OperatorService.java:181)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:559)
    Oct 30, 2013 10:42:53 PM com.rapidminer.operator.LifeStyle_Marketing.LifeStyle_Targeting WriteLog
    SEVERE: Error com.rapidminer.operator.ports.metadata.MetaData cannot be cast to com.rapidminer.operator.ports.metadata.ExampleSetMetaData .
    Oct 30, 2013 10:42:54 PM com.rapidminer.tools.plugin.Plugin registerOperators
    Oct 30, 2013 10:42:56 PM com.rapidminer.tools.OperatorService init
    INFO: Number of registered operator classes: 952; number of registered operator descriptions: 1,078; number of replacements: 577
    Oct 30, 2013 10:42:57 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
    Oct 30, 2013 10:42:57 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    Oct 30, 2013 10:43:43 PM com.rapidminer.gui.ApplicationPerspectives loadAll
    Oct 30, 2013 10:43:44 PM com.rapidminer.elico.ida.IDAPluginInit initGui
    Oct 30, 2013 10:43:44 PM com.rapidminer.elico.ida.gui.dockable.WelcomeStep whitify
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@61f835,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import Excel Sheet...,defaultCapable=true]
    INFO: Whitify javax.swing.JButton[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.5,border=com.rapidminer.gui.look.borders.EmptyButtonBorder@61f835,flags=424,maximumSize=,minimumSize=,preferredSize=,defaultIcon=jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/icons/24/import.png,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=10,left=20,bottom=10,right=20],paintBorder=true,paintFocus=true,pressedIcon=,rolloverEnabled=true,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Import CSV File...,defaultCapable=true]
    INFO: Whitify com.rapidminer.gui.tools.ExtendedHTMLJEditorPane[,0,0,0x0,invalid,layout=javax.swing.plaf.basic.BasicTextUI$UpdateHandler,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.basic.BasicBorders$MarginBorder@224b7e,flags=296,maximumSize=,minimumSize=,preferredSize=,caretColor=javax.swing.plaf.ColorUIResource[r=0,g=25,b=100],disabledTextColor=javax.swing.plaf.ColorUIResource[r=180,g=180,b=180],editable=false,margin=javax.swing.plaf.InsetsUIResource[top=4,left=6,bottom=4,right=6],selectedTextColor=javax.swing.plaf.ColorUIResource[r=255,g=255,b=255],selectionColor=javax.swing.plaf.ColorUIResource[r=150,g=150,b=170],kit=com.rapidminer.gui.tools.ExtendedHTMLEditorKit@1ee64e6,typeHandlers=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@4a8179,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.LineBorder@17a6052,flags=9,maximumSize=java.awt.Dimension[width=410,height=210],minimumSize=java.awt.Dimension[width=410,height=210],preferredSize=java.awt.Dimension[width=410,height=210]]
    rm.log.1 part 2/2
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=200,height=200],minimumSize=java.awt.Dimension[width=200,height=200],preferredSize=java.awt.Dimension[width=200,height=200],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.JPanel[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.EmptyBorder@249fc0,flags=9,maximumSize=java.awt.Dimension[width=620,height=1000],minimumSize=java.awt.Dimension[width=620,height=80],preferredSize=java.awt.Dimension[width=620,height=210]]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=350,height=250],minimumSize=java.awt.Dimension[width=350,height=100],preferredSize=java.awt.Dimension[width=350,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    INFO: Whitify javax.swing.JScrollPane[,0,0,0x0,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=com.rapidminer.gui.look.borders.ScrollPaneBorder@11ea2a,flags=328,maximumSize=java.awt.Dimension[width=500,height=250],minimumSize=java.awt.Dimension[width=500,height=100],preferredSize=java.awt.Dimension[width=500,height=100],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.rapidminer.gui.look.ui.ScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=293601288,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=]
    Oct 30, 2013 10:43:45 PM com.rapidminer.elico.ida.installer.InstallerUtils readCurrentVersion
    Oct 30, 2013 10:43:46 PM com.rapid_i.deployment.update.client.UpdateManager checkForUpdates
    CONFIG: Ignoring update check. Last update check was on 10/30/13 7:08 PM.
    Oct 30, 2013 10:43:48 PM com.rapidminer.elico.ida.installer.IDAUpdater checkForUpdateNow
    Oct 30, 2013 10:43:48 PM com.rapidminer.io.community.MyExperimentConnection connectTo
    Oct 30, 2013 10:43:54 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
    Oct 30, 2013 10:43:54 PM com.rapidminer.gui.ApplicationPerspectives saveAll
    Oct 30, 2013 10:43:55 PM com.rapidminer.tools.usagestats.UsageStatistics save
    at com.rapidminer.gui.RapidMinerGUI$ShutdownHook.run(RapidMinerGUI.java:217)
    at com.rapidminer.RapidMiner.quit(RapidMiner.java:804)
    at java.awt.EvanceentDispatchThread.pumpEventsForFilter(Unknown Source)
    end of rm.log.1
    thank you in advance
    manolis
    Hi,
    there seems to be a problem loading some extensions. I do not know what causes this from here, so could you please try the following:
    Move (not copy) all .jar files from USER/.RapidMiner5/managed folder somewhere else. All .jars in said folder are loaded as plugins, so moving them somewhere else will remove those extensions from RapidMiner for the time being. Afterwards please look into your RM installation folder, specifically in the lib/plugins subfolder. Are there also extensions in there? If so, move them to a backup place as well. Now start RapidMiner, it should load no plugins at all. Now go to the Update/Marketplace dialog again, and select only the web mining plugin. It should tell you that there is a depdency (text mining). After you have downloaded them both, restart RapidMiner as requested. Can you now see the "Text Processing" and "Web Mining" operator categories?
    If so, you can now re-add the other extensions you need. Check after each one that the others are still functional, in case there is a conflict. If there is or any other problem arises, feel free to ask.
    Regards,
    Marco
    It seems that my problem solved.
    I understand now the way of debug.
    thank you very much for your help
