🎉Community Raffle - Win $25
Join and Win
"Saving weka model [Solved]"
User: "ammargh"
New Altair Community Member
Updated by Jocelyn
What is the best way to save weka models for further use?
I have tried "store" and "write model" components without any success
Thank you.
1 - 4 of 41
    User: "MariusHelf"
    The Store operator is the way to go. You can use it with a combination of Retrieve and Apply Model in another process. If you still have problems please let us know and supply what exactly does not work.
    Best regards,
    Marius
    User: "ammargh"
    OP
    I have found the problem and I think it is good that I report it.
    I am working on a private data on a machine that cannot have access to the internet. I have installed RM but I cannot install the extensions, therefore, I have installed the extensions manually by copying the jar file into the plugins directory.
    Storing and retrieving Weka models did not work.
    Later, I have copied the extensions into the plugins/managed directory with the XMLfile and I was able to retrieve Weka models by the Retrieve component
    User: "MariusHelf"
    Hm, that's strange. Which plugins directory did you use? To make it work you have to copy the extensions to C:\Program Files\Rapid-I\RapidMiner5\lib\plugins (i.e. in the installation directory, C:\Program Files\RapidMiner\RapidMiner5\lib\plugins for the latest version), not to the .RapidMiner5\plugins folder in your home directory. Did you do that?
    User: "ammargh"
    OP
    Yes, first I used  "C:\Program Files\Rapid-I\RapidMiner5\lib\plugins"  but I had an error retrieving weka models.
    It worked only when I copied the folder " C:\Program Files\Rapid-I\RapidMiner5\lib\plugins\managed" from another machine.
    I have double checked.
