"Export Association Rules Result"
Hi All,
Now im working on association rules model. I have a problem to export the result to excel. I need it to do next data analysis.
I try to use "write excel" operator after "Association Rules generator" operator, but it said that it need example set.
In Association Rules Result view..there only export as pdf too...
Any suggestion to solved this problem.
Thanks in advance.
Thanks in advance.
if you want to do the next data analysis within RapidMiner you should use the Store operator to store the association rules in the repository. You can then use Retrieve to get the rules into the next process.
To export them to Excel the easiest way is probably to mark the complete table in the results view, press Ctrl-C to copy the table and paste it into Excel. There is no automated way of doing this.
Best regards,
Marius
