Altair RISE
Nominate Yourself Now!
Rigid pole impact analysis using RADIOSS
User: "HYOJUNG KIM"
Altair Community Member
Updated by HYOJUNG KIM
Hi. I'm a student using RADIOSS solver.
I'm doing rigid pole impact analysis using RADIOSS solver.
But I have a problem.
When the structure consist of shell element collide with pole, the deformation does not occur and the analysis is end.
I think this problem happened because of element or contact.
Please help me.
And i attach my RAD file.
Thank you.
1 - 1 of 11
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    There were a few odd things in the model, no parameters had been set on the contact apart from friction, I set gap, stiffness etc, and also made it a self contact
    You had rotational SPC constraints on all tray nodes, not sure why, but I deleted them
    I also moved your tray a lot closer so you don't waste time modelling free flight.
    You didn't send your engine, so I added my own
    My Model Attached
