[SOLVED]Add a rank column
texnoti
texnoti New Altair Community Member
edited November 2024 in Community Q&A
Hi all!
Just started with RapidMiner.
Got so far that I'm calculating what I want.
Ended up with this result:
38.898
42.052
43.455
Now, in the next step I only care about what place it is, so how do I add a column with 1, 2, 3?
It's not always three, it varies.
Kind regards
thomas
Welcome!
Answers
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    Sort and Generate ID should do it.
    ~Martin
  • texnoti
    Hi, yes it did.
    But...
    now I'm trying with Loop Values and Filter because I got data as:
    1,23.256
    1,35.655
    2,56.899
    2,57.122
    Tried condition_class = attribute_value_filter but I get an error.
    How should I set up the filter to process 1's and 2's (and 3's, 4's and ...) separate?
  • texnoti
    Ok, got it!
    attribute=%{loop_value}
    Now it's just a matter of merge, right?
    Thanks!
  • MartinLiebig
    MartinLiebig
    Altair Employee
    propably,
    maybe you need to know that append also appends collections.
    Martin
Welcome!
Welcome!
