🎉Community Raffle - Win $25
Join and Win
"storing csv file data in database using Rapidminer"
User: "Raman"
New Altair Community Member
Updated by Jocelyn
I want to store CSV file content in MYSQL database using Rapidminer. But the problem is -
Database error occured: attribute reviewText contains values with length>255 which is the maximum length for columns of SQL type VARCHAR.
and i also checked the set default varchar length. But it does not resolve my problem.
1 - 2 of 21
    User: "Marco_Boeck"
    Hi,
    you have 2 options: Either during import change the column type to "text" or use the "Nominal to Text" operator before your "Write Database" operator. In both cases the resulting SQL column will be of a TEXT type.
    Regards,
    Marco
    User: "Raman"
    OP
    [SOLVED ] thank you so much Sir... It works.
