Can't import CSV data on Mac
Hi
I'm new here. I'm just getting started with RapidMiner.
I'm trying to import a csv file and clicking import csv doesn't do anything.
Am I missing something? I've followed tutorials and in them a wizard appears, which doesn't happen in my case.
The only three options that work are import access, database and binary.
1 - 18 of
181
Well, I'm on 10.6.8 thus Java 6... Unresolvable as far as I know...
I'm on Mountain Lion and using RM 5.3.013. I have Java 7.
I opened RM from inside the scripts folder by double clicking RapidMinerGUI.
When the tool started the first time, I was not prompted for creating a new repository. I started a New Process and then created a new repository. If I try to import a .csv, I get nothing and there's not error messages either.
Can someone help?!
Can someone help?!
Thanks Marco
The funny thing is that in my java preferences under Java Runtime Environment Settings, I only see 1.7. The Java Control Panel is available in my System Preference and that means my system is using Java 7 (I think) but when I run the command Java -version in my terminal, it still returns:
java version "1.6.0_43"
Java(TM) SE Runtime Environment (build 1.6.0_43-b01-447-11M4203)
Java HotSpot(TM) 64-Bit Server VM (build 20.14-b01-447, mixed mode)
I am at a complete loss on forcing my system to use Java 7.
Hi,
The same thing happened to me. Two things got it working:
Open the Java Preferences Utility (Applications > Utilities) and move Java 7 to the top. [This is different from the System Preferences, which, as you've seen, doesn't do any good.]
I did this before I figured out the Preferences, so don't know how much difference it made. I installed the Java Developer's Kit (JDK), I think from the advice of another post on here.
Good luck!
Good luck!
Well, following these steps has broken my RM installation.
I proceeded with the following steps.
Removed Java 6
Installed Java 7 SDK
Set JAVE_HOME to new Java 7 location
Set Path to include new Java location
On RM start it bombs out with the following error:
Thanks in advance.
Removed Java 6
Would be grateful if someone could point me in the right direction.
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fff8d7f4221, pid=18806, tid=52231
# JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.45-b08 mixed mode bsd-amd64 compressed oops)
# Problematic frame:
# C [libGLImage.dylib+0x24221] storeColor+0x5d1
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /Users/paulalford/Desktop/rapidminer/hs_err_pid18806.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
./scripts/RapidMinerGUI: line 195: 18806 Abort trap: 6 $JAVA $ADDITIONAL_OPTIONS -Xmx${MAX_JAVA_MEMORY}m -XX:MaxPermSize=128m -cp ${CLASSPATH} -Drapidminer.home=${RAPIDMINER_HOME} -Drapidminer.operators.additional=${RAPIDMINER_OPERATORS_ADDITIONAL} ${RAPIDMINER_JDBC_DRIVER_PARAMETER} com.rapid_i.Launcher "$@"
Thanks in advance.
This same problem is happening to me. I am running Java 7 SDK. I got RM to run on my Macbook air running Mountain Lion, but cannot get it to import CSV or excel. When I try to use the Import data command, nothing happens....
Reshma wrote:
Nothing is returned. It's blank.
I suspect we need to set this in some type of profile?
On my iMac running Mavericks, I cannot even get RM to open, it shows the loading screen, then the GUI crashes with a message similar to what Paul Alford reports. I don't know enough about the code to be able to understand what it's doing wrong or how to fix it.
I had exactly the same problem. I'm running Mavericks and Rapidminer Version 5.3.13.
I had Java 7 installed but Mac was not using it (when i ran "java -version" I got the version 1.6).
I followed the steps described in the page:
http://apple.stackexchange.com/questions/58116/enabling-java-7-on-mountain-lion
and everything works as expected after that.
Having the same issues on Mavericks with RM 5.3.015. If Java 7 is installed, RM crashes out at GUI start with EXC_BAD_ACCESS (see below).
If I remove Java 7 and use Apple Java 6, then RM starts but neither CSV, Excel, nor XML import work.
Following the steps linked by earmijo didn't fix the issues for me.
Process: java [25570]
Path: /Library/Internet Plug-ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Identifier: net.java.openjdk.cmd
Version: 1.0 (1.0)
Code Type: X86-64 (Native)
Parent Process: Jar Launcher [25568]
Responsible: Jar Launcher [25568]
User ID: 504
Date/Time: 2013-11-06 20:47:55.362 -0600
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Anonymous UUID: F61A03F4-5353-DF22-5E4D-AE96814852A5
Sleep/Wake UUID: FF8CA141-1196-4FCF-8599-A5ED31115931
Crashed Thread: 29 Java: Java2D Queue Flusher Dispatch queue: com.apple.root.default-priority
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000012376e000
Version: 1.0 (1.0)
User ID: 504
Report Version: 11
