[Resolved] Import (menu or wizard) CSV, Excel and XML doesn't work
User: "colmoni"
New Altair Community Member
Updated by Jocelyn
Resolved - Rapidminer uses JRE 7, was using JRE 6. Confirmed: Using JRE 7 fixes the problem
I'm currently using the zip-unpacked Java version of RapidMiner to analyse SurveyMonkey responses to open-ended questions, stored as spreadsheets.
I note that attempting to use the import Wizard doesn't work for CSV, Excel or XML. Clicking the menu or button does absolutely nothing - nothing in the log either.
I can import the files manually using the Read Excel or CSV nodes, but as I'm new to the application, would like the assistance of the wizard.
I've investigated the INSTALL.txt file and could find no trace of these configuration files:
[tt]  RAPID_MINER_HOME/rapidminerrc
 RAPID_MINER_HOME/rapidminerrc.OSNAME
 ~/.RapidMiner5/<VERSION>rapidminerrc
 ~/.RapidMiner5/<VERSION>rapidminerrc.<OSNAME>
 rapidminerrc
 rapidminerrc.<OSNAME>[/tt]
I'm uncertain if this has anything to do with the problem?
1 - 9 of 91
    Hi,
    are you using MacOS? Which version of RapidMiner are you using?
    Regards,
    Marco
    User: "colmoni"
    OP
    Marco Boeck wrote:
    Hi,
    Regards,
    Marco
    No, Windows 7 (32-bit). It's a company machine, and the restrictions the administrators put on it are the bane of my life, which is why I'm using the Zip version of RM.
    Hi,
    can you please post the contents of the rm.log file (user/.RapidMiner5/rm.log) after you restarted RapidMiner and tried to open an Import wizard via "File" -> "Import Data" -> "Import Excel Sheet..."?
    Regards,
    Marco
    User: "colmoni"
    OP
    Marco Boeck wrote:
    Hi,
    Regards,
    Marco
    The following represents me launching RM, starting a New Process, clicking each of the three options in turn, then shutting down. Must of the content appears to be generated by the inability to contact the update server, it being blocked by the firewall:
    Sep 17, 2013 3:59:36 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
    INFO: Default version of expression parser registered successfully
    Sep 17, 2013 3:59:38 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
    WARNING: Password in XML file looks like unencrypted plain text.
    Sep 17, 2013 3:59:38 PM com.rapidminer.tools.OperatorService init
    INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
    Sep 17, 2013 3:59:39 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    Sep 17, 2013 3:59:39 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    Sep 17, 2013 3:59:48 PM com.rapidminer.gui.ApplicationPerspectives loadAll
    CONFIG: Loading perspectives.
    Sep 17, 2013 3:59:48 PM com.rapid_i.deployment.update.client.UpdateManager$3 run
    INFO: Checking for updates.
    Sep 17, 2013 4:00:04 PM com.rapidminer.gui.tools.WelcomeScreen$2 run
    INFO: Cannot download news: java.net.ConnectException: Connection timed out: connect
    at java.net.PlainSocketImpl.socketConnect(Native Method)
    at java.net.PlainSocketImpl.doConnect(Unknown Source)
    at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
    at java.net.PlainSocketImpl.connect(Unknown Source)
    at java.net.SocksSocketImpl.connect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at sun.net.NetworkClient.doConnect(Unknown Source)
    at sun.net.www.http.HttpClient.openServer(Unknown Source)
    at sun.net.www.http.HttpClient.<init>(Unknown Source)
    at sun.net.www.http.HttpClient.New(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
    at java.net.HttpURLConnection.getResponseCode(Unknown Source)
    at javax.swing.JEditorPane.getStream(Unknown Source)
    at javax.swing.JEditorPane.setPage(Unknown Source)
    at com.rapidminer.gui.tools.WelcomeScreen$2.run(WelcomeScreen.java:259)
    Sep 17, 2013 4:00:07 PM com.rapidminer.gui.OperatorDocLoader parseDocumentForOperator
    WARNING: Could not open http://rapid-i.com/wiki/index.php?title=Process: connect timed out
    Sep 17, 2013 4:00:09 PM com.rapid_i.deployment.update.client.UpdateManager$3 run
    WARNING: Error checking for updates: javax.xml.ws.WebServiceException: Failed to access the WSDL at: http://marketplace.rapid-i.com:80/UpdateServer/UpdateServiceService?wsdl. It failed with:
    Connection timed out: connect.
    at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(Unknown Source)
    at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.parse(Unknown Source)
    at com.sun.xml.internal.ws.client.WSServiceDelegate.parseWSDL(Unknown Source)
    at com.sun.xml.internal.ws.client.WSServiceDelegate.<init>(Unknown Source)
    at com.sun.xml.internal.ws.spi.ProviderImpl.createServiceDelegate(Unknown Source)
    at javax.xml.ws.Service.<init>(Unknown Source)
    at com.rapidminer.deployment.client.wsimport.UpdateServiceService.<init>(UpdateServiceService.java:42)
    at com.rapid_i.deployment.update.client.UpdateManager.getService(UpdateManager.java:567)
    at com.rapid_i.deployment.update.client.UpdateManager$3.run(UpdateManager.java:870)
    at com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:200)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    Caused by: java.net.ConnectException: Connection timed out: connect
    at java.net.URL.openStream(Unknown Source)
    at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.createReader(Unknown Source)
    at com.sun.xml.internal.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(Unknown Source)
    ... 13 more
    Sep 17, 2013 4:00:50 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
    INFO: Running shutdown sequence.
    Sep 17, 2013 4:00:50 PM com.rapidminer.gui.ApplicationPerspectives saveAll
    CONFIG: Saving perspectives.
    Sep 17, 2013 4:00:50 PM com.rapidminer.tools.usagestats.UsageStatistics save
    CONFIG: Saving operator usage.
    Hi,
    I don't see anything in your log which would indicate a problem which might cause this issue, which is rather strange. I also could not reproduce the issue on any test machine here, everything works fine, so this might be a little bit tricky to figure out. Can you please start the RapidMinerGUI.bat script from the command line (found inside the RapidMiner5/scripts folder), and paste the whole output here? You can copy & paste from the windows command line via rightclick -> select all and then leftclick in the upper left corner on the icon, go to Edit and then select copy.
    Regards,
    Marco
    User: "colmoni"
    OP
    Here's the dump from command line - I rat the bat file and clicked the three Import options:
    C:\Users\doe-morrisonc\rapidminer\scripts>RapidMinerGUI.bat
    RAPIDMINER_HOME is not set. Trying the directory 'C:\Users\doe-morrisonc\rapidmi
    ner\scripts\..'...
    Using global jre found on path: java
    Starting RapidMiner from 'C:\Users\doe-morrisonc\rapidminer\scripts\..' using cl
    asses from 'C:\Users\doe-morrisonc\rapidminer\scripts\..\lib\rapidminer.jar'...
    Creating file "C:\Users\doe-morrisonc\AppData\Roaming\check_rm_java_version"
    Java Version: 1.6.0_11
    Removing file "C:\Users\doe-morrisonc\AppData\Roaming\check_rm_java_version"
    Starting in multicore mode with CMS garbage collector...
    18-Sep-2013 09:57:52 com.rapid_i.Launcher ensureRapidMinerHomeSet
    INFO: rapidminer.home is 'C:\Users\doe-morrisonc\rapidminer\scripts\..'.
    18-Sep-2013 09:57:57 com.rapid_i.Launcher main
    INFO: Launching RapidMiner, platform ANY
    18-Sep-2013 09:58:00 com.rapidminer.tools.ParameterService init
    INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
    18-Sep-2013 09:58:00 com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    18-Sep-2013 09:58:00 com.rapid_i.Launcher ensureRapidMinerHomeSet
    18-Sep-2013 09:58:01 com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: VISUALIZATIONS
    INFO: Register plugin: R Extension
    INFO: Register plugin: Text Processing
    INFO: Register plugin: Web Mining
    18-Sep-2013 09:58:02 com.rapidminer.PluginInitR initPlugin
    INFO: Trying to load R Library...
    18-Sep-2013 09:58:04 com.rapidminer.tools.expression.parser.ExpressionParserFact
    ory <clinit>
    18-Sep-2013 09:58:06 com.rapidminer.parameter.ParameterTypePassword decryptPassw
    ord
    18-Sep-2013 09:58:06 com.rapidminer.tools.OperatorService init
    INFO: Number of registered operator classes: 514; number of registered operator
    descriptions: 532; number of replacements: 437
    18-Sep-2013 09:58:07 com.rapidminer.tools.jdbc.JDBCProperties <init>
    18-Sep-2013 09:58:07 com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    not installed.
    [Fatal Error] :1:1: Premature end of file.
    18-Sep-2013 09:58:13 org.rosuda.JRI.Rengine <clinit>
    INFO: Creating Connection to R...
    18-Sep-2013 09:58:13 org.rosuda.JRI.Rengine isJriLoaded
    WARNING: Access on uninitialized Rengine!
    INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:PluginClassLoader ([fi
    le:/C:/Users/doe-morrisonc/rapidminer/scripts/../lib/plugins/rmx_r-ANY-5.3.0.jar
    18-Sep-2013 09:58:16 com.rapid_i.deployment.update.client.UpdateManager$3 run
    18-Sep-2013 09:58:30 com.rapidminer.gui.tools.WelcomeScreen$2 run
    nect
    Source)
    ce)
    urce)
    Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: canno
    t add to layout: constraint must be a string
           at java.awt.CardLayout.addLayoutComponent(Unknown Source)
           at java.awt.Container.addImpl(Unknown Source)
           at java.awt.Container.add(Unknown Source)
           at com.rapidminer.operator.nio.LoadingContentPane.<init>(LoadingContentP
    ane.java:49)
           at com.rapidminer.operator.nio.CSVSyntaxConfigurationWizardStep.makePane
    l(CSVSyntaxConfigurationWizardStep.java:279)
           at com.rapidminer.operator.nio.CSVSyntaxConfigurationWizardStep.<init>(C
    SVSyntaxConfigurationWizardStep.java:129)
           at com.rapidminer.operator.nio.CSVImportWizard.<init>(CSVImportWizard.ja
    va:75)
    va:48)
           at com.rapidminer.gui.MainFrame$1.actionPerformed(MainFrame.java:322)
           at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
           at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
           at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
           at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
           at javax.swing.AbstractButton.doClick(Unknown Source)
           at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
           at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown
    Source)
           at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
           at java.awt.Component.processMouseEvent(Unknown Source)
           at javax.swing.JComponent.processMouseEvent(Unknown Source)
           at java.awt.Component.processEvent(Unknown Source)
           at java.awt.Container.processEvent(Unknown Source)
           at java.awt.Component.dispatchEventImpl(Unknown Source)
           at java.awt.Container.dispatchEventImpl(Unknown Source)
           at java.awt.Component.dispatchEvent(Unknown Source)
           at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
           at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
           at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
           at java.awt.Window.dispatchEventImpl(Unknown Source)
           at java.awt.EventQueue.dispatchEvent(Unknown Source)
           at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
           at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
           at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
           at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
           at java.awt.EventDispatchThread.run(Unknown Source)
    18-Sep-2013 09:58:32 com.rapidminer.gui.OperatorDocLoader parseDocumentForOperat
    or
    timed out
    18-Sep-2013 09:58:39 com.rapid_i.deployment.update.client.UpdateManager$3 run
    own Source)
    ource)
    urce)
    e)
    e)
    n Source)
    anager.java:567)
    r.java:870)
    Source)
    ce)
    urce)
    known Source)
    nown Source)
           ... 13 more
    ane.java:49)
           at com.rapidminer.operator.nio.AnnotationDeclarationWizardStep.<init>(An
    notationDeclarationWizardStep.java:55)
           at com.rapidminer.operator.nio.AbstractDataImportWizard.addCommonSteps(A
    bstractDataImportWizard.java:60)
           at com.rapidminer.operator.nio.ExcelImportWizard.<init>(ExcelImportWizar
    d.java:72)
    d.java:48)
           at com.rapidminer.gui.MainFrame$2.actionPerformed(MainFrame.java:338)
    Source)
    ane.java:49)
           at com.rapidminer.operator.nio.MetaDataDeclarationWizardStep.<init>(Meta
    DataDeclarationWizardStep.java:258)
           at com.rapidminer.operator.nio.xml.XMLImportWizard.<init>(XMLImportWizar
    d.java:81)
    d.java:51)
           at com.rapidminer.gui.MainFrame$3.actionPerformed(MainFrame.java:354)
    Source)
    It seems those Import options trigger a lot of calls to Java libraries of 'unknown source'
    I checked my Java version:
    C:\Users\doe-morrisonc\Desktop>java -version
    java version "1.6.0_11"
    Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
    Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
    Argh!
    In order to use RapidMiner you need a Java Runtime Environment (JRE) version 7
    http://rapid-i.com/content/view/17/40/lang,en/#installation:step1
    User: "colmoni"
    OP
    Thanks for the help, it pushed me in the right direction for a solution. Really should have RTFM!
    User: "paulalford"
    Hi,
    I have encountered the same problem as colmoni, but the difference is that I'm running Mac OSX.  When starting the Java 7 download I get the following message:
    "If you download Java 7, you will not be able to run Java content in Chrome and will need to use a 64-bit browser (such as Safari or Firefox) to run Java content within a browser. Additionally, installing Java 7 will disable the ability to use Apple Java 6 on your system".
    Is there a workaround for Mac users?
    My current Java version is:
    java version "1.6.0_65"
    Java(TM) SE Runtime Environment (build 1.6.0_65-b14-462-11M4609)
    Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-462, mixed mode)
    Thanks in advance.
    User: "bmoose"
    paulalford,
    You can have several versions of JDK installed on your Mac.
    Open http://www.java.com/en/download/installed.jsp?detect=jre&;try=1 in your Safari browser (not Chrome)
    It will tell you if you have java 1.7. If you do you should see Java in your System Preferences.
    Click on Java tab and "View..."
    Under Path you'll see where Java 7 is installed.
    Edit scripts/RapidMinerGUI script to hardcode JAVA_HOME to point to the location of Java 1.7
    It should resolve your issue with RapidMiner and will not affect anything else.
    paulalford wrote:
    Hi,
    Thanks in advance.
