🎉Community Raffle - Win $25
Join and Win
sum columns ??
eselvaUser: "eselva"
New Altair Community Member
Updated by Jocelyn
i new in rapidminer, but  i dont know how to sum or average one column
1 - 3 of 31
    Hi,
    you can do this using the aggregate operator. It works similar to the aggregate in SQL.
    ~Martin
    OP
    i cant it.  I just sum one colum? how?
    Hi eselva,
    try out the process below. This should illustrate it.
    Martin
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.5.002">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="120">
            <parameter key="repository_entry" value="//Samples/data/Sonar"/>
          </operator>
          <operator activated="true" class="aggregate" compatibility="6.5.002" expanded="true" height="76" name="Aggregate" width="90" x="179" y="120">
            <list key="aggregation_attributes">
              <parameter key="attribute_1" value="sum"/>
            </list>
          </operator>
          <connect from_op="Retrieve Sonar" from_port="output" to_op="Aggregate" to_port="example set input"/>
          <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
