Select Terms
gustavo_medeiro
gustavo_medeiro New Altair Community Member
edited November 2024 in Community Q&A
Hi, Everybody
I don't if the topic is in correct place. Anyway...
Is it possible to make a filtering of the terms as follows in RapidMiner?
Supose:
NA - Number of occurrence of a word in Class A
NB - Number of occurrence of a word in Class B
NC - Number of occurrence of a word in Class C
Total = NA + NB + NC
They remain the terms that meet the following criteria:
(NA / Total) * 100%> X% or (NB / Total) * 100%> Y% or (CN / Total) * 100%> Z%
Is it possible?
Welcome!
Answers
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Sure,
    tokenize, generalte attributes and filter example should do that.
  • gustavo_medeiro
    Classes are defined by the value of "label1" which are respectively -1, 0, 1. Suppose I want to remain the only terms which meet the following criteria:
    ([occurrence of words with label1] = -1) / total)> 0.7
    ([occurrence of words with label1] = -0) / total)> 0.7
    ([occurrence of words with label1] = 1) / total)> 0.7
    Total =[ Occurrence in label1= -1] + [ Occurrence in label1= 0] +[ Occurrence in label1= 1]
    What should I write on the fields inside "Generate Attribuite" and "Filter Examples"?
    I cannot sendo the image to show you better. But there are fields to be filled inside "Generate Attribuite" and "Filter Examples".
  • gustavo_medeiro
    Do the people here abandoned me?
  • MartinLiebig
    MartinLiebig
    Altair Employee
    no,
    but you posted at x differnt threads got different answers and i do not know what the status is.
    ~Martin
  • gustavo_medeiro
    I did not know the correct place this is a reason I had done it.
  • gustavo_medeiro
    What should I do now?
Welcome!
Welcome!
