"Decision Tree Data"
Hi everyone,
I'm trying to build a decision tree with 190000 lines of information but when I start the process the following message appears:
Process Failed
o
Process failed.
Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflectinvocalionTargetExceplion. Target: java.lang.RunlimeExceplion: Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflectinvocalionTargetExceplion. Target: java.lang.OutOfhlemoryError: Java heap space. Cause: java.lang.OutOfhlemoryError: Java heap space.. Cause: java.lang.RunlimeExceplion: Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflectinvocalionTargetExceplion. Target: java.lang.OutOfhlemoryError: Java heap space. Cause: java.lang.OutOfhlemoryError: Java heap space..
Send Bug Report...
dose
Is this data to big for rapid or there's another possibility to do this decision tree.
Thanks
Process Failed
o
Process failed.
Send Bug Report...
dose
Thanks
