🎉Community Raffle - Win $25
Join and Win
Using Maps with rapid miner
supadhyayaUser: "supadhyaya"
New Altair Community Member
Updated by Jocelyn
HI ,
I have a table which contains userIDs and their IP address. I want to display the density of user according to the region where they are loggin in from using a MAP.
can anybody tell me if rapid miner has digrams / plots which will let me visualize the density using the MAP (something like map of the world)
Regards,
supadhyaya
1 - 6 of 61
    Hi!
    RapidMiner has no ready-to-use functions for this.
    You could geocode the IP addresses using the Maxmind GeoIP database: http://dev.maxmind.com/geoip/geoip2/geolite2/
    For map display, you always need to select a "map projection" and transform the coordinates accordingly.
    Then, using the reporting operator, you export a scatterplot with the transformed coordinates. This plot could be laid over a base map.
    It's quite an involved process, not really easy.
    I'd do the display part using an online map server software like OpenLayers http://www.openlayers.org, Leaflet http://leafletjs.com/ or an offline map generator like MapServer's shp2img tool: http://mapserver.org/en/utilities/shp2img.html.
    ReneUser: "Rene"
    Yes, one could use the GeoIP database to recode IPs into longitude & latitude or country data. Then I'd suggest you to use RapidMiner's R extension. R has some nifty functions to plot geo data with no effort.
    Thank you guys,
    Yes I also think that the process you mentioned is really involving but surely is worth trying... Once again I thank for your advice. I am taking it and working on it currently..
    Cheers
    You could try the community edition of SPLUNK with the google plugin to do what you want to achieve.
    MBMUser: "MBM"
    So for example when I have lat and long as points on a Map in RM usinge R extension can I use the points that are displayed for clustering?
    Yes, you can use the points that are displayed for clustering provided you write your R code to pass that data back to a RapidMiner process.
    Something like this:
    rm_main=function(data)
    library maplibrary
    some R code to generate your stuff
    data <- mylatlongforclustering
    return (data)
