1 - 7 of
71
Thanks a lot for your answer. I downloaded canopy to have python and theano because the alternative choises for having theano with python failed(not compatible cuda etc). Everything work fine in canopy. I put the path for python( in the canopy forder) for the python operator and the panda detection was correct but i have a warning that do data was delivered at port. I'm running the default script thas the python operator has but the procces failed. I think that the default script can run without connect something there is that right? the message is 'script terminated abnormally'
Do you know what i'm missing to have it to work correct?
This is an old discussion but still...
The new release 7.2 has Deep Learning:
https://rapidminer.com/gradient-boosted-trees-deep
Have fun,
Ingo
1 - 1 of
11
Have fun,
Ingo
not yet. But you can call theano with the python extension.
Best,
Martin
