🎉Community Raffle - Win $25
Join and Win
"Aggregate and remove attributes"
User: "Jony"
New Altair Community Member
Updated by Jocelyn
Hi,
I have a data set containing 2000 columns or attributes having values as real number. What i want to do is aggregate (sum) three attributes and create a new attribute with the summing result and remove the last two leaving first attribute and the resulting attribute. I can do that by using operators generate attribute (sum) and remove range. But i want to impose this procedure to the whole 2000 attributes, that means three attributes will be summed leaving two attributes (including resulting one) and then next three will be summed leaving two attributes and so on. Is there any procedure that i can impose that generate attribute and remove range to the whole data set automatically or is there any other procedure to do it? please let me know if you need more specifications.
Jony
