R error crashes RM
User: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
In R,
grep('\d','1')
results in
Error: '\d' is an unrecognized escape in character string starting "\d"
(because it should have been '\\d')
But in RM
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="r:execute_script_r" compatibility="5.3.000" expanded="true" height="60" name="pushChart" width="90" x="313" y="75">
       <parameter key="script" value="grep('\d','1')"/>
       <enumeration key="inputs"/>
       <list key="results"/>
     </operator>
   </process>
 </operator>
</process>
causes an abrupt termination of RM, without any prompts or messages.
1 - 1 of 11
    User: "Nils_Woehler"
    Hi,
    I've had a look into this and it seems like we can't do anything about it The library we are using creates a JRI session to R.
    When providing the command you've posted this session even crashes the Java Runtime Environment:
    # A fatal error has been detected by the Java Runtime Environment:
    #  Internal Error (os_windows_x86.cpp:149), pid=10952, tid=10904
    #  guarantee(result == EXCEPTION_CONTINUE_EXECUTION) failed: Unexpected result from topLevelExceptionFilter
    # JRE version: 7.0_07-b11
    # Java VM: Java HotSpot(TM) 64-Bit Server VM (23.3-b01 mixed mode windows-amd64 compressed oops)
    # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
    # An error report file with more information is saved as:
    # C:\Users\nwoehler\workspace\RapidMiner\hs_err_pid10952.log
    # If you would like to submit a bug report, please visit:
    http://bugreport.sun.com/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    I'm going to file an issue for this, but probably there is no easy fix for this.
    Best,
    Nils
