[SOLVED]How to iterate over Attributes
Hello RM-Team,
I tried to iterate over the attributes with the "loop attributes"-operator, but the "select attributes"-operator seems not to work well within a loop
It only work's on the first cycle, thats why I think its not my fault. Could you tell me if this is a bug, and maybe when you will fix it?
Best xDSticker
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Put a breakpoint on the SAtt-operator and see the difference between the output at the first cycle and the other one's.
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="179" y="30">
<parameter key="number_examples" value="10"/>
</operator>
<operator activated="true" class="loop_attributes" compatibility="5.3.008" expanded="true" height="76" name="Loop Attributes" width="90" x="313" y="30">
<operator activated="true" breakpoints="after" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="30">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="%{loop_attribute}"/>
</operator>
<connect from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="example set"/>
<portSpacing port="source_example set" spacing="0"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/>
<connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
Best xDSticker
1 - 3 of
31
Some of the loop operators (the ones with ports named "exa") behave differently from the rest. While other loop operators pass the same initial exampleset into each iteration, these loop operators pass the output "exa" from one iteration to the input "exa" of the next, in effect forming an iterated chain of the internal operators. The advantage of this (in most applications) is that you end up getting one exampleset at the loop operator's output, rather than a collection.
Because of this "chaining" your process amounts to selecting att1 from {att1,att2,att3,att4,att5} and then selecting att2 from {att1}, which is why it doesn't work.
You could usually just use the macro to work directly on the full exampleset without first selecting. But if you really want to select each attribute into a different exampleset you could do it like this
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
<operator activated="true" class="loop_attributes" compatibility="5.3.008" expanded="true" height="94" name="Loop Attributes" width="90" x="313" y="30">
<operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="30">
</operator>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
<connect from_op="Select Attributes" from_port="original" to_port="example set"/>
</process>
</operator>
<connect from_op="Loop Attributes" from_port="result 1" to_port="result 1"/>
</process>
</operator>
</process>
Connect the output of the Select Attribute operator to the RES output.
Matthew
