Parametric CFD Study Acusolve 2019.1
User: "granzer_22210"
Altair Community Member
Updated by unknown
I need help setting up this simple case in Acuconsole-Hyperstudy (Surface and volume mesh was constructed in Hypermesh). I have a simple rectangular duct containing a heat generating body in the middle of the duct. I am wondering of its possible to create the 'inlet-velocity' as a 'parameters' and give 5 different inlet velocity for a DOE study in HyperStudy. I want to study the effect of inlet velocity on Volumetric average temperate of the heated body, so I need response as the volumetric-average temperature.  Also, can you provide some material to setup a simple DOE study with varying inlet velocity.
1 - 8 of 81
